87 SI
Old May 14, 2002 | 12:32 AM
HatchSteer's Avatar
Default 87 SI
What engines can fit into the bay of an 87 Civic HB?
I own an 87 Civic SI HB and it needs to be faster... any suggestiions?
Old May 14, 2002 | 04:21 AM
wronghand's Avatar
Default Re: 87 SI (BitterCivic)
D16A1
Old May 14, 2002 | 04:40 AM
RacerBoy's Avatar
Default Re: 87 SI (wronghand)
D16A1, the 86-87 integra DOHC engine bolts right in. 113 hp to start. Not to bad on a 1800 lb. car! You can get it damn cheap and install is easy for some Joe Blow mechanic. Some simple bolt ons, build the engine slightly before it goes in you'll have a 14 car EASY.
Old May 14, 2002 | 05:44 AM
wronghand's Avatar
Default Re: 87 SI (RacerBoy)
Pick up a set of ZC cams. That will bump the hp on the D16A1 as well.
Old May 14, 2002 | 05:54 AM
crxfanatic's Avatar
New User
The b16 fits right in with the use of the Hasport kit. Problem is, this route is expensive, ~$1000 more than a b16 into an 88-91 car.
Old May 14, 2002 | 08:32 AM
Brandon Chun's Avatar
Default Re: 87 SI (crxfanatic)
Wow how come its $1000 more?
Old May 14, 2002 | 08:42 AM
crxfanatic's Avatar
New User
Default Re: 87 SI (Brandon Chun)
When I did my buds, it was even more, but basically, the mounts and harness from Hasport is alot more, you have to get Teg knuckes, Hasport axle shafts and some old inner/outer cvs and boots...
Of course if you're resourceful it could be less, but the cost of extra stuff for this swap just piled up, unlike the swap into my bud's 91 CRX.
Old May 14, 2002 | 09:00 AM
johnny hatchback's Avatar
http://www.3rdgencivic.com
lots of info. and a messageboard.
Old May 14, 2002 | 09:49 AM
Ham'ed Hatch
Guest
Posts: n/a
anything'll fit if you have the resourses. save for a bseries, you'll LOVE it.
Old May 14, 2002 | 12:01 PM
rpr's Avatar
rpr
Default Re: 87 SI (HoMoCo FoLife)
Also brown top ZC and teg black top ZC will bolt in just as easily as a D16A1, just more hp, although the distributor is different on the black top.
Old May 14, 2002 | 07:24 PM
-TJ's Avatar
-TJ
Default Re: 87 SI (rpr)
HASport probably figures that there isn't nearly the market for the B-series swap in a 84-87, so they jack up the price to compensate for low volume.
Any D16A1 bolts in - regardless of valve cover color. The 88-89 D16A1 requires "advanced" wiring.
CRXJunkie
19
May 21, 2005 04:51 PM
D15B2civic
Jan 20, 2005 06:25 PM
illogic65
19
Oct 6, 2004 02:39 PM
12secWRX
Dec 29, 2002 10:43 PM
HatchSteer
May 14, 2002 01:36 AM
