Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
my crv is having a problem
Old Jan 4, 2007 | 07:17 AM
crvpimpin's Avatar
Default my crv is having a problem
i havent been able to realy track it down yet but
i was driving the other day and i turned on my blinker to turn and the car died. i restarted it and then it imediatly died agian. so i waited a few seconds then tryed to restart agian and it started, but not far it died agian no blinker
and i had to wait a few minutes this time befor it would restart the car wasat normal temps and i figuredit had somthing to do with something over heating because it was fine after i let it cool for a few minutes, also the srs light came on after this second time not sure if it was related
but it was doing fine for the last few days then driving home from work today it happened agian just like befor but the drive home is only like no more than 5 miles and would have barely had time to warm up so im realy confused as to what this might be
any guess's as to what i might wanna check would be good
(i already checked the fuses)
thanks
Old Jan 4, 2007 | 11:10 PM
PnX-R's Avatar
Default Re: my crv is having a problem (crvpimpin)
Try looking at your coolant temp gauge when the car dies. What is showing you?.. If you have to let it cool first, I've seen a few CRV's come in overheating w/o the customer knowing. After it cools down, it starts up fine.
Old Jan 10, 2007 | 01:19 PM
Perfectionist's Avatar
Mentioning the vintage of your CRV would help. If it's older, maybe a battery problem, maybe loose cable(s), ignition switch, etc.
Old Jan 13, 2007 | 01:46 PM
crvpimpin's Avatar
Default Re: my crv is having a problem (Perfectionist)
the coolant temp was normal every time it happend
its a 98 crv sorry
so i took it in yesterday to my lcal honda to check it out they scaned th ecu and shut off the srs light they said it was form something that wasnt happening any more so i dont know about that but didnt mention anything else
and it did it agian tonight so im lost now
Old Jan 14, 2007 | 05:27 AM
Ross 2.0's Avatar
In a Junkyard near you.
check your receipt to see what the code was
Old Jan 15, 2007 | 01:56 PM
crvpimpin's Avatar
Default Re: (Ross 4107)
i'll check for it later but im not sure if anything useful will be there because we're in germany right now but no luck with contacting honda yet
i hope it turns out good
bobjohnson
10
Oct 31, 2007 09:38 PM
ih8sndq
Jun 30, 2007 08:04 PM
crvpimpin
Jan 13, 2007 01:48 PM
Quik89Si
Aug 15, 2002 04:44 PM
