adjusting brakes... --searched
Old Jan 4, 2007 | 07:16 AM
92civicfreak's Avatar
Default adjusting brakes... --searched
i seared, but recived little or no info/topics about this
how do i raise the pedal? i just did the DA swap & noticed that the pedal was down quite low & once pumped, it would come back up... would adjusting the screw on the booster help?
Old Jan 4, 2007 | 08:19 AM
Furyof4's Avatar
Default Re: adjusting brakes... --searched (92civicfreak)
What MC are you using? If you are using the stock one, the pedal will have to travel further to fill the larger calipers. If you have to pump the pedal to get good pressure than you have air in the lines or your MC is bad.
Old Jan 4, 2007 | 08:25 AM
i've got non abs DA booster, 4040 pro valve, & DA 15/16 mc
Old Jan 4, 2007 | 08:29 AM
i bled the brakes properly & when i am at a light on a hill, the pedal doesn't sink to the floor as it would if i had air in my lines
Old Jan 4, 2007 | 08:36 AM
Furyof4's Avatar
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">i bled the brakes properly & when i am at a light on a hill, the pedal doesn't sink to the floor as it would if i had air in my lines</TD></TR></TABLE>
If you have to pump the pedal up then you could still have air in there. Ive had the same problem before, bled the brakes 4 times till I got all the air out. They can be a bitch to bleed sometimes. Did you bench bleed the MC? Is the MC new or used?
Old Jan 4, 2007 | 08:53 AM
Default Re: (Furyof4)
no i didn't bench bleed it & it is used... got it froma junk yard
but even befor my friend got into the car i gravity bled the brakes... so what do u suggest? bleed them again? & if so, how should i do it.. i got no money so i cant really get any pumps or anything... should i have my friend mash down on the pedal when i do it? and should i do it w/ the resevoir cap on or off?
Old Jan 4, 2007 | 09:34 AM
Loserkidwac's Avatar
Bench bleed the MC before you install it, it takes a while but if you don't do it you iwll have air in the lines...also you need to bleed the brakes in a proper order, i believe it is DR,PF,PR,DF (D=Drivers Side R=Rear etc...) try that and then see if that helps
Old Jan 4, 2007 | 10:35 AM
ok since the mc is ALREADY installed what should i do? & how long would it take to do it?
Old Jan 4, 2007 | 02:52 PM
bump
Old Jan 4, 2007 | 03:11 PM
4thgenhtch's Avatar
i believe RR, LR, RF, LF is the order???? Id like to know for sure also
Old Jan 4, 2007 | 03:12 PM
MC has to be removed to bench bleed you can't do it on the car...you need to push the piston in further than it acctually goes in when you push the pedal, it sucks but you have to do it, maybe 1 out of 10 times you can get away with out having to do it but its rare...remove it bench bleed and then bleed the brakes in the order I posted before and see if that fixes it
coot_er
23
Oct 13, 2021 07:27 AM
goldfinger93030
Sep 19, 2010 07:33 PM
ekek888
May 1, 2007 09:25 AM
bb4ninja
Jun 17, 2006 06:39 PM
