Whats the advantages of using a aftermarket LCA?
Old Jan 4, 2007 | 06:44 AM
dem0nk1d's Avatar
Default Whats the advantages of using a aftermarket LCA?
i've been looking around at the Omni, and Blow lower control arm for my EG Civic hatchback. What's the advantages of running a aftermarket LCA? Any at all or is it mostly for appearance.
Old Jan 4, 2007 | 06:55 AM
pdiggitydogg's Avatar
Some have different hole locations (or more holes) for sway bar mounting...more adjustability...
Youre going to probably get some that claim "weight savings" but really...its minimal, at best.
Old Jan 4, 2007 | 07:01 AM
ek-j's Avatar
Default Re: (pdiggitydogg)
they look cool! lol
Old Jan 4, 2007 | 07:23 AM
JDM_teh_WIN!!'s Avatar
Default Re: (ek-j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-j &raquo;</TD></TR><TR><TD CLASS="quote">they look cool! lol</TD></TR></TABLE>
LOL.
But honestly, they are lighter, stronger, and like the poster above said, they have the advantage to use an adjustable swaybar/endlinks.
I believe Function7 and Skunk2 have alternative holes for mounting.
Old Jan 4, 2007 | 07:35 AM
MidwestSiR's Avatar
Default Re: (JDM_teh_WIN!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">I believe Function7 and Skunk2 have alternative holes for mounting. </TD></TR></TABLE>
Functions do for sure
Old Jan 4, 2007 | 07:39 AM
Cvic90's Avatar
Mine move the trailing arm in to gain room for the wheel to clear the quarter panel when lowered. When I put them on, I gained +1.5 degrees of camber. Then, when I lowered the car again, it was between 0 and -.5 degrees instead of -2 to -2.5.
Old Jan 4, 2007 | 07:51 AM
sniggler316's Avatar
Default Re: (Cvic90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 &raquo;</TD></TR><TR><TD CLASS="quote">Mine move the trailing arm in to gain room for the wheel to clear the quarter panel when lowered. When I put them on, I gained +1.5 degrees of camber. Then, when I lowered the car again, it was between 0 and -.5 degrees instead of -2 to -2.5.</TD></TR></TABLE>
What ones do you have?
Old Jan 4, 2007 | 08:18 AM
kangaroo's Avatar
same here. They allow for wider tires to be used.
Mine are the SPC lca's.
Old Jan 4, 2007 | 08:23 AM
Default Re: (kangaroo)
Are you using adjustable camber and toe parts as well?
Old Jan 5, 2007 | 07:00 AM
Cvic90's Avatar
I am using an adjustable upper arm too. I'm not sure what brand my lower arms are though. I'm at the limits of my compensator arms also. It would be a good idea to get adjustable ones but, you can get away without them.
Old Jan 5, 2007 | 07:21 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (ek-j)
x1000000
Nah but also, along with what everyone already said, the stock LCAs may form rust and the bushings get really old so buying new aftermarkets ends up being cheaper than buying brand new OEMs.
Old Jan 5, 2007 | 07:32 AM
MasterKwan's Avatar
Default Re: (SkoundrelUSA)
I don't like the aftermarket arms because most use polyurethane bushings which shouldn't be used on the LCA to trailing arm and LCA to body mounts. The LCA's from Honda are $100 a pair. If they get old and/or rusty, just pop a new set on.
Old Jan 5, 2007 | 07:40 AM
Default Re: (MasterKwan)
I just want to know why you would use LCAs to correct camber if you have adjustable camber in the rear? Are you using a wide *** tire or something? What is the reason for getting camber correcting LCAs. Why did you have so much Negative camber to begin with?
Old Jan 5, 2007 | 07:43 AM
Malakai's Avatar
im guessing his car was dropped pretty low.
Old Jan 5, 2007 | 07:57 AM
Default Re: (Malakai)
Seems kind of odd. You should be able to adjust the camber with a rear camber kit.
Old Jan 5, 2007 | 08:09 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">I don't like the aftermarket arms because most use polyurethane bushings which shouldn't be used on the LCA to trailing arm and LCA to body mounts. The LCA's from Honda are $100 a pair. If they get old and/or rusty, just pop a new set on. </TD></TR></TABLE>
I am not sure where you are got that info from. It is fine to use poly on the lower control arm. The only one you shouldn't use it is the rear trailing arm bushing because it doesn't let that arm to move correctly
Old Jan 5, 2007 | 08:21 AM
kangaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Are you using adjustable camber and toe parts as well?</TD></TR></TABLE>
yes I also have a rear camber kit on.
It's not so much that I bought the LCA to correct my camber but I just wanted it because it looks cool.
The benifits are just that it also allows for wider tires to be used. I'm not running anything outrageous. There just 205/50/15. It just pulls the tire and wheel in more so it's not so close to the fender.
I find that the 205 sits perfectly in the wheel well while my 195/50/15 kind of tuck into the wheel well more.
Old Jan 5, 2007 | 08:22 AM
Sleepy_Red_hatch's Avatar
i got mine because it was a killer deal and less trouble then putting new bushings in a "new" lca
Old Jan 5, 2007 | 08:23 AM
EM1FORLIFE.'s Avatar
lighter, but its more for the bling factor.
Old Jan 5, 2007 | 08:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kangaroo &raquo;</TD></TR><TR><TD CLASS="quote">
Are those curved or just shorter in length?
Old Jan 5, 2007 | 08:34 AM
kangaroo's Avatar
I don't know but they look like this. ^^^^^
Old Jan 5, 2007 | 08:51 AM
Hmmm ok. How much camber can you dial in with those? Seems like not much.
Old Jan 5, 2007 | 09:21 AM
kangaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm ok. How much camber can you dial in with those? Seems like not much.</TD></TR></TABLE>
Beats me??????
Old Jan 5, 2007 | 03:11 PM
MasterKwan's Avatar
The LCA body and trailing arm bushings move on multiple axis just like the trailing arm bushing does. So, that's why you don't want them to be poly. It's not nearly as noticable as the trailing arm bushing but, there is some binding.
twophastprelude
30
Jul 28, 2007 01:57 PM
o2flow.net
11
Jul 12, 2006 11:32 AM
sldcivic
Jan 20, 2006 01:01 AM
SkRiBLaH
Oct 17, 2005 09:46 AM
24valvage
Apr 22, 2003 11:19 PM
