swappin back stock cam gears
Old Jan 4, 2007 | 05:41 AM
danteisme's Avatar
Loved
Community Favorite
Default swappin back stock cam gears
im swapping back in my stock cam gears on my gsr. i came across this page:
http://www.evotuners.com/camgears.htm
a bout half way down the page it says "mark the timing belt at tdc and lock the tensioner so that it doesnt tighten up when you take the belt of the gears."
how exactly does one do that? from what i was told by a few people, you dont even need to take off the bottom covers, you can just slip the belt off the gears and put the new ones on.
Old Jan 4, 2007 | 07:55 AM
95 integra's Avatar
Default Re: swappin back stock cam gears (danteisme)
The tensioner is already "locked" in its current state, generally you have to loosen a 14mm bolt to unlock the tensioner to get the belt off. You can "generally" slip the belt off, its pretty easy to get off and can be a bit harder to get back on.
92EG8
Nov 2, 2008 03:41 AM
B16b-EJ8
Sep 7, 2007 01:42 PM
boomersz
Feb 24, 2007 08:19 PM
-Championship-
Aug 5, 2006 09:06 PM
Tomakit
Oct 26, 2001 02:40 PM
