welding tips
Old Jan 4, 2007 | 12:14 AM
Timmay's Avatar
Default welding tips
im about to so some shaving of my engine bay and some of the spots are pretty thin metal.. i really don't want to mess it up and burn through.. what would be a good setting for something like that
its just a basic wire feed welder and we use gas.. also maybe there i a better type of wire for something like that?
Old Jan 4, 2007 | 08:59 PM
Timmay's Avatar
Default Re: welding tips (Timmay)
Old Jan 4, 2007 | 09:10 PM
RCautoworks's Avatar
Use thinner wire, .030 or .035 will do, pull the trigger then stop, basically spot weld.
Old Jan 4, 2007 | 09:26 PM
Timmay's Avatar
Default Re: welding tips (90blackcrx)
yea we have .35 wire right now
what kind of speed and heat settings work for thinner stuff?
Old Jan 4, 2007 | 09:29 PM
How thin ? Usually the lowest setting
Old Jan 4, 2007 | 09:56 PM
Timmay's Avatar
engine bay of a civic.. the side metal is pretty thin
Old Jul 10, 2019 | 09:34 PM
slim_towerz's Avatar
This is a great write up. Thank you. But the pictures arent loading for me.
Old Jul 19, 2019 | 04:04 PM
Emmy's Avatar
magnetic copper plates... the heavier the better. keeps it from blowing thru, but dont try using pennies. Dissasterous results!!
Old Oct 31, 2019 | 06:30 PM
grsabourin's Avatar
Use thin wire it will help. Best will be to have access to a TIG welder
Old Oct 31, 2019 | 07:46 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Copper is non-ferrous....
But you have the right idea. Also an aluminum backer will work.
Old Jan 15, 2020 | 10:04 PM
C1V3I2C0's Avatar
Good stuff. I was looking for some info on this myself. Not to mention the rusted through holes in the floorboard I need to find a way to fix.
that-guy
Welding / Fabrication
17
Jun 20, 2011 06:16 AM
that-guy
12
Mar 23, 2011 09:48 AM
EFnerd
14
Apr 22, 2008 09:39 PM
91ed9
20
Dec 15, 2007 11:59 AM
cdog19
Feb 3, 2004 10:39 AM
