LS HANDLING COMPARED TO GSR
Old Jan 3, 2007 | 09:28 PM
TOO MUCH TORQUE's Avatar
Default LS HANDLING COMPARED TO GSR
is there any difference?
is it night and day ?
Old Jan 3, 2007 | 09:37 PM
slow_ls's Avatar
No difference besides I believe the rear sway bar is like 1mm bigger.
Old Jan 3, 2007 | 09:38 PM
PrinceAli132's Avatar
Default Re: LS HANDLING COMPARED TO GSR (TOO MUCH TORQUE)
No noticable difference IMO.
Ali
Old Jan 4, 2007 | 02:06 PM
anymore experience
Old Jan 4, 2007 | 03:24 PM
tomithy's Avatar
Default Re: LS HANDLING COMPARED TO GSR (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">No noticable difference IMO.
Ali</TD></TR></TABLE>
Old Jan 4, 2007 | 03:28 PM
Default Re: (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">anymore experience</TD></TR></TABLE>
Honestly, even if there was a slight difference (which there isn't) it makes no difference. Do you plan on keeping the car stock?
If not then you'll probably at some point want to upgrade your suspension components, therefore yielding a great handling car when done right.
Ali
Old Jan 4, 2007 | 04:09 PM
mrdeadman's Avatar
They let me pick
If the ls doesn't have a sunroof, technically it should handle slightly (but not noticeably) different on account of a lower COG, but for your purposes they are equivalent.
Old Jan 4, 2007 | 04:25 PM
Boots's Avatar
Default Re: LS HANDLING COMPARED TO GSR (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">If the ls doesn't have a sunroof, technically it should handle slightly (but not noticeably) different on account of a lower COG, but for your purposes they are equivalent. </TD></TR></TABLE>
by definition all ls models came with a sunroof...rs's didnt so it would be an rs
Old Jan 4, 2007 | 05:14 PM
Schister66's Avatar
Man U FTW
I think either one with a good set of tires is going to handle nicely. Once i got my new tires, my GSR rode like it was on rails.
Old Jan 4, 2007 | 06:27 PM
mrdeadman's Avatar
They let me pick
Default Re: LS HANDLING COMPARED TO GSR (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">
by definition all ls models came with a sunroof...rs's didnt so it would be an rs</TD></TR></TABLE>
I thought it was optional on the LS, standard on the GS... but whatever.
Old Jan 4, 2007 | 06:28 PM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was optional on the LS, standard on the GS... but whatever.</TD></TR></TABLE>
its the other way around...but i was just busting your *****
Old Jan 4, 2007 | 06:31 PM
mrdeadman's Avatar
They let me pick
its the other way around...but i was just busting your ***** </TD></TR></TABLE>
I call BS it's not the other way around, take the cards. GS is the upper model right before the GSR.
Old Jan 4, 2007 | 08:26 PM
all the ls ive seen have sunroofs
Old Jan 4, 2007 | 08:38 PM
Ichigo's Avatar
buy gsr front strut bar and its pretty much the same.
Old Jan 4, 2007 | 08:50 PM
dc2-slow's Avatar
what about ls and itr. are there any differences?
Old Jan 4, 2007 | 08:55 PM
-Darren-'s Avatar
Default Re: LS HANDLING COMPARED TO GSR (imadickted2yu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadickted2yu &raquo;</TD></TR><TR><TD CLASS="quote">what about ls and itr. are there any differences?</TD></TR></TABLE>
yes, there is a really big difference in handling between the itr and all other intergras.
Old Jan 4, 2007 | 09:13 PM
-Championship-'s Avatar
76.169.175.137
Default Re: LS HANDLING COMPARED TO GSR (-Darren-)
sway bar is different, pretty much the whole suspension is upgraded, bigger rotors and brake calipers...and the JDM 98 spec ITR is even better
Old Jan 4, 2007 | 09:17 PM
gsr dood's Avatar
Default Re: LS HANDLING COMPARED TO GSR (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr &raquo;</TD></TR><TR><TD CLASS="quote">sway bar is different, pretty much the whole suspension is upgraded, bigger rotors and brake calipers...and the JDM 98 spec ITR is even better </TD></TR></TABLE>
thats not true. ur thinking of the type r. the gsr only has a front strut tower bar compared to an LS. all the suspension components are the same. rotors calipers springs struts etc are all the same
Old Jan 4, 2007 | 09:33 PM
what does a front strut bar do?
Old Jan 4, 2007 | 09:39 PM
http://www.team-integra.net/se...D=293
Ali
Old Jan 4, 2007 | 09:43 PM
vincepru's Avatar
all stock 4dr tegs handle like complete **** IMO
Old Jan 4, 2007 | 09:57 PM
76.169.175.137
Default Re: LS HANDLING COMPARED TO GSR (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">
thats not true. ur thinking of the type r. the gsr only has a front strut tower bar compared to an LS. all the suspension components are the same. rotors calipers springs struts etc are all the same </TD></TR></TABLE>
forgot to quote the comment above me
Old Jan 5, 2007 | 04:20 PM
GsDAteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote"> I call BS it's not the other way around, take the cards. GS is the upper model right before the GSR. </TD></TR></TABLE>
I own a 91' GS four door with no a/c, sunroof, or power locks and it came that way from the factory. My buddy also owns a 90' GS hatch back with no power locks or a/c stock.
Old Jan 5, 2007 | 05:37 PM
mrdeadman's Avatar
They let me pick
Default Re: (GsDAteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg &raquo;</TD></TR><TR><TD CLASS="quote">
I own a 91' GS four door with no a/c, sunroof, or power locks and it came that way from the factory. My buddy also owns a 90' GS hatch back with no power locks or a/c stock. </TD></TR></TABLE>
We are referring to the 94-01 models when the GS came stock with all the options.
Old Jan 5, 2007 | 07:51 PM
JDMorgan's Avatar
only way there might be a slight difference would be comparing an rs to a gsr, only because of the weight difference. four door should actually handle a little better if skunk 2 is correct when saying that the four door is more rigid. i never noticed any difference in handling between any tegs i've driven, besides ones with aftermarket or messed up suspension.
