Koni shocks...questions bout them
Old Jan 3, 2007 | 07:30 PM
guero2craze's Avatar
Default Koni shocks...questions bout them
wat are the pros and cons on the yellow konis...i want to pair them up some h&R springs .75"drop or the swift 1.1"drop
Old Jan 3, 2007 | 07:39 PM
soundFX's Avatar
Default Re: Koni shocks...questions bout them (guero2craze)
well im about to buy koni yellows with Ground Controls and i had to do a lot of research in order to come to this conclusion and i suggest u research some yourself, but the pros are that konis are damper adjustable which is always a plus, they are made extremely well, they have a lifetime warranty.they are for sleeve style coilovers which means they will lose some travel but depending on what coilover you pair them up with you will be good. i hope this makes sense and if it doesnt just search. it helps.
Old Jan 3, 2007 | 07:54 PM
PrinceAli132's Avatar
They also come with 3 spring perches. So even though you are using springs you can still slightly adjust the height depending upon which perch you use.
Lifetime warranty and if they need to be rebuilt/revalved they have a facility to do so in the US.
Also, in the suspension forum there are shock dyno's if your interested.
IMO, i don't think its a con but to some the price may be a bit high. But I feel that they are totally worth it. I have had them on my car for over 2 years and more than 25K miles with atleast a 2.5 inch drop and they are still in perfect working condition.
Ali
Old Jan 4, 2007 | 05:56 AM
okay so im gettin the konis yellow...wat springs should i get...i have a 94 gsr with fat fives rims and i want the wheel well to be like a finger or two gap between them...wat should i get...
Old Jan 4, 2007 | 06:15 AM
reno96teg's Avatar
i'll answer your questions if you can tell me what the hell is so hard about typing out "what"?
Old Jan 4, 2007 | 06:19 AM
Default Re:
wat springs shoudl i get cuz i dont want coilovers...
Old Jan 4, 2007 | 06:29 AM
be.twenty's Avatar
Default Re: Re: (guero2craze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guero2craze &raquo;</TD></TR><TR><TD CLASS="quote">wat springs shoudl i get cuz i dont want coilovers...</TD></TR></TABLE>
whatever springs float your boat.... any ots spring should work fine with the yellows
Old Jan 4, 2007 | 06:41 AM
Default Re: Re: (be.twenty)
i dont kno how much to drop it to get the wheel well to be a finger or two gap from the tire...
Old Jan 4, 2007 | 11:44 PM
vladd's Avatar
how many threads are you gonna start with the same topic? read your other thread.
go2sleep
Suspension & Brakes
Apr 7, 2015 02:57 PM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
cuban
Nov 13, 2006 08:26 PM
hu
Feb 11, 2006 08:05 PM
Mr_Moos
Suspension & Brakes
Jan 27, 2006 06:13 PM
