2000 si pressure switch missing
Old Jan 3, 2007 | 07:14 PM
em1electron69's Avatar
Default 2000 si pressure switch missing
my friends stock b16 head has a v tec solenoid all in place and functioning but today we noticed that the is a plug plu that should conect to the pressure switch ann its just hanging when i tried to hook it up i noticed that is has no plug inlet on the solenoid mount well under the solenoind it is covered, as in stock covered. can i just buy the plug that goes there or should i buy a whole new solenoid mount that comes with it??? and how does not having my pressure switch affect my car???? THANX 4 LOOKING
Old Jan 3, 2007 | 07:20 PM
EJgsr's Avatar
Default Re: 2000 si pressure switch missing (em1electron69)
well first off V-tec will not work...
and you can buy the little plug from honda for pretty cheap
Old Jan 3, 2007 | 07:23 PM
Brick Top's Avatar
if your just wanting the pressure switch alone, im sure its available. and not having it i think causes vtec not to work.
Old Jan 3, 2007 | 07:31 PM
Default Re: 2000 si pressure switch missing (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">well first off V-tec will not work...
and you can buy the little plug from honda for pretty cheap</TD></TR></TABLE>
but we could swear that we feel it kick in at 5200 he even has the vtec controller and it kicks in. the only thing that trips me out is the the whole where the plug should go is covered with a thick plastic could that just be removed....
also what is the purpose of the pressure switch???
Old Jan 3, 2007 | 07:50 PM
bump for answers
Old Jan 3, 2007 | 08:26 PM
MasterKwan's Avatar
The pressure switch isn't used by JDM ECU's. Only we Americans who can't be bothered to check our oil, get the pressure switch as a baby sitter.
I hook mine up when I run a US ECU and don't bother when I use my JDM ECU. The pressure switch is nothing more than an oil pressure sensor set to a higher pressure than the useless* one plugged into the block. It'll prevent vtec when you're low on oil.
*Useless because if you see the oil pressure light on, you've probably already done damage to your motor.
hondatuner020
Mar 23, 2015 04:48 PM
GSR_hatch936
May 17, 2008 11:39 AM
allnapower
Apr 23, 2005 08:23 PM
Toadfart
Jan 20, 2005 12:17 AM
