im about to snap... poor honda
Old Jan 3, 2007 | 06:05 PM
s_vares's Avatar
Default im about to snap... poor honda
Well, I have an LS motor in my car at high RPM it falls on its ***.
Seems to have lots of torque and no HP.
Whats the deal
Im running a stock civic exhaust no cat.
with LS computer and CAI no other mods no CEL
Old Jan 3, 2007 | 06:23 PM
boosstboy's Avatar
Default Re: im about to snap... poor honda (s_vares)
what rpm are u taking it up to? ls motors weren't made to make power up to 8000 rpm like like a v-tec motor. it probely looses power after 6500 rpm.
Old Jan 3, 2007 | 06:27 PM
jdeemseerx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares &raquo;</TD></TR><TR><TD CLASS="quote">Seems to have lots of torque and no HP.
You pretty much described an LS motor perfectly.. If its obviously not running right and stumbling up top you might want to check out the plugs.. and possibly invest in a tuneup (cap, rotor, wires) etc..
Old Jan 3, 2007 | 06:35 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares &raquo;</TD></TR><TR><TD CLASS="quote">Well, I have an LS motor in my car at high RPM it falls on its ***.
Whats the deal
with LS computer and CAI no other mods no CEL</TD></TR></TABLE>
there is ur problem
Old Jan 3, 2007 | 06:37 PM
NMZ's Avatar
NMZ
run a cat
youre ruining th eenvironment with your slow piece of **** u stupid ricer
Jimmy's Avatar
Global Moderator
Default Re: im about to snap... poor honda (super-hatch)
What do you expect? All your doing is bottlenecking your engine and restricting the hell out of it with a stock civic exhaust
Old Jan 3, 2007 | 06:38 PM
MasterKwan's Avatar
If you're running a stock LS tranny, that's also a problem. They fall on their faces once you hit 3rd gear.
Old Jan 3, 2007 | 06:41 PM
poison's Avatar
Hard to determine the exact problem. But start with doing regular maintenance. Cap, rotor, plugs, wires, fuel filter, etc..
Old Jan 3, 2007 | 06:57 PM
schardbody's Avatar
man, where did real tech go. nobody has helped him yet, just tryed to make him look stupid.
90% of the people with swaps use the stock exhaust for that chassis w/out a problem, so that is NOT the problem, and a gutted cat isnt going to make power drop off at the top of the band.
OP: check your ignition and cam timing, then make sure all your general maintenance items are in good shape (plugs, wires, cap, rotor, fuel filter, etc) check fuel pressure, etc.... if you have NO codes its not something serious enough to make the ECU notice it, most likely something simple. what ecu are you running by the way.
Old Jan 3, 2007 | 08:01 PM
EJAYATE's Avatar
I Deliver
Default Re: (schardbody)
I think he said no cat, which probably means no o2 sensor. I don't know about an ls motor, but if he has no o2 sensor that could be his problem. From the information he's given us thats about all we can tell him. You can always say check this do that but your still just guessing. More info please.
Old Jan 3, 2007 | 09:50 PM
FCUKU's Avatar
have you tried replacing your stock exhaust? i believe your restricting teh air flow sir.
Old Jan 3, 2007 | 09:51 PM
Jimmy's Avatar
Global Moderator
Default Re: (FCUKU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FCUKU &raquo;</TD></TR><TR><TD CLASS="quote">have you tried replacing your stock exhaust? i believe your restricting teh air flow sir. </TD></TR></TABLE>
Thank you captain obvious.. Are you blind?
Old Jan 3, 2007 | 10:12 PM
bmoua's Avatar
bro you think thats bad...try driving a ej8 with a y8 haha...man sucks *****...the only fun you almost get out of it is 1st gear haha...
Old Jan 4, 2007 | 03:42 PM
schardbody's Avatar
Default Re: (FCUKU)
ARE YALL serious??? you do realize the STOCK exhaust will support WAY more than 120whp.
Old Jan 4, 2007 | 07:41 PM
SinglecamMitch's Avatar
timing maybe?? i would check the ignition also...
Old Jan 4, 2007 | 08:14 PM
pdiggitydogg's Avatar
unless we get a little more detail...it sounds just like an ls engine
they just do not perform at high rpm
Old Jan 5, 2007 | 12:59 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">ARE YALL serious??? you do realize the STOCK exhaust will support WAY more than 120whp. </TD></TR></TABLE>
Yes i'm dead ******* serious.. It sound like he's wanting his engine to perform like a racecar and it simply won't 1)Because it's a honda 2) because he has a stock engine and three to simply clear this up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">unless we get a little more detail...it sounds just like an ls engine
they just do not perform at high rpm</TD></TR></TABLE>
/thread.
Old Jan 5, 2007 | 02:35 AM
schardbody's Avatar
i agree jimmy, we need more info to help any further but 4 damn people said stock exaust, and its just not possible that the stock exhaust is TOO small for the LS.
Old Jan 5, 2007 | 02:54 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">i agree jimmy, we need more info to help any further but 4 damn people said stock exaust, and its just not possible that the stock exhaust is TOO small for the LS.</TD></TR></TABLE>
Then that brings up back to..where he's wanting a civic with a bone stock engine be fast.. and i guess he needs to realize.. hey we're driving hondas
the.hamburglar
Sep 2, 2007 08:05 PM
myke
26
Jun 8, 2007 12:30 AM
hatchy69
54
Feb 23, 2007 03:03 PM
fackyou
Apr 29, 2006 10:09 AM
JSJ EG6
Nov 21, 2003 11:18 AM
