help with car not starting
I had a few electrical things to take care of today. I reset the SRS light and I was wiring in a potentiometer since my ECU is looking for a fuel tank sensor that my certain year car doesnt have.
I finished and my car won't start. It wont even crank. When I try, my climate control lights turn off ( not fade ) and a single click under the dash can be heard.
All my fuses are good and my battery seems to be fine since my stereo plays crisp and loud. I don't think it's my ECU because I unplugged it to try to crank the engine.
I need some help.
The car is a '97 Civic w/ a GSR swap and a USDM p72 obd2a ecu
I've directed this to a new thread: https://honda-tech.com/zerothread?id=1853913
Modified by FuNkDrSpOt at 12:13 AM 1/4/2007
I need some help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">your car wont start without the ecu!. it wont even crank.
also it helps to know what car/motor and ecu your using
Obviously the car won't start without the ecu but it will crank. How do i know? Because I cranked the car while unplugging the ecu to push oil in my oil cooler that I just installed.
</TD></TR></TABLE>Obviously the car won't start without the ecu but it will crank. How do i know? Because I cranked the car while unplugging the ecu to push oil in my oil cooler that I just installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">check the main relay... most failing part on honda's</TD></TR></TABLE>
Would the main relay just go out all of a sudden? The car was working fine earlier. BTW, where is the main relay
@ me
Modified by FuNkDrSpOt at 7:23 PM 1/3/2007
@ meModified by FuNkDrSpOt at 7:23 PM 1/3/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">Any recommendations? Any fuses I might want to recheck? Anything? </TD></TR></TABLE>
BUMP!
BUMP!
BUMP!</TD></TR></TABLE>
spyz34
Mar 20, 2005 12:49 PM
