FS B series Exedy Lightweight Racing Flywheel LIKE NEW!
FOR USE ON: INTEGRA 1.8L, INTEGRA 1.7L, CIVIC Si 1.6L (DOHC), CIVIC DEL SOL 1.6L (DOHC)
WEIGHT: 9.46 lbs.
RING GEAR TEETH: 112
FLYWHEEL BOLTS: 8
MATERIAL: Billet Steel Chromoly
This was going to be used on my H2B setup but seeing as it is not aluminum, I can't use it
Modified by amy at 10:13 PM 1/3/2007
WEIGHT: 9.46 lbs.
FLYWHEEL BOLTS: 8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godruler »</TD></TR><TR><TD CLASS="quote">will this work on a 90-91 cable tranny?? if so what you want for it?? Pm me back, i'll lose track of this thread.</TD></TR></TABLE>
not a clue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">why do you need aluminum?
how much you looking for, amy?</TD></TR></TABLE>
cause my flywheel spacer is alum, so it needs to be matching material so when it heats up it'll heat together and cool down together - all that expanding and constricting
not a clue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">it'll heat together and cool down together - all that expanding and constricting </TD></TR></TABLE>
ewwww, perv...
so what are you asking for?
ewwww, perv...
Richard Noggin
Jan 29, 2008 06:31 AM
hammerdgolfer
Aug 26, 2004 12:57 AM
