no spark and i cant figure out why
Old Jan 3, 2007 | 04:19 PM
3.point.2's Avatar
Default no spark and i cant figure out why
for some reason my engine is not getting spark. ive checked and replaced the ignition coil, the dizzy and rotor seem fine, my spark plugs and wires are ok. what else could it be? when my car died i smelled something that smelled like wires frying. ive checked all fuses. when the car sits long enough itll start and run for about 5 seconds and shut off. im completely clueless on this problem. any one have any ideas?
Old Jan 3, 2007 | 04:26 PM
dustinO's Avatar
if it runs it is getting spark
could be allot of things
Old Jan 3, 2007 | 04:28 PM
excivicboy96's Avatar
Default Re: (integraca)
If you smelt wires frying you could have had a small electrical fire. Possibly the power needed for the spark is making a short to ground. I would try and locate the burning smell.
Old Jan 3, 2007 | 04:38 PM
3.point.2's Avatar
Default Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote"> If you smelt wires frying you could have had a small electrical fire. Possibly the power needed for the spark is making a short to ground. I would try and locate the burning smell.</TD></TR></TABLE>
i could only smell it when it happened which was like a month ago. any ideas of what could have fried and where it would be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraca &raquo;</TD></TR><TR><TD CLASS="quote">if it runs it is getting spark
could be allot of things</TD></TR></TABLE>
it only gets spark for a few seconds when its been sitting for a while. otherwise no spark
Old Jan 3, 2007 | 06:16 PM
Default Re: (h23eg)
I suggest checking wires inside the harness. Electrical fires suck if they start when theres a bunch of wires together rather than being by them selves. Check for any exposed wiring Starting at the spark plugs and working your way back. A wiring diagram would help a lot
murray195
Jun 10, 2007 12:57 PM
b16b18
Sep 6, 2006 12:56 PM
e jay one
Mar 4, 2006 06:02 PM
95turbohatch
24
Apr 7, 2004 08:07 PM
whoobeedoobee
Aug 6, 2003 05:03 PM
