knock sensor
Old Jan 3, 2007 | 04:16 PM
blk crx's Avatar
Default knock sensor
i have a 93 civic cx about 4 weeks ago i put in a jdm b16a well my problum started about a week ago i get a check engine light for the knock sensor and then i'll turn the car off and it will be gone so can a knock sensor go bad
Old Jan 3, 2007 | 04:28 PM
poison's Avatar
Default Re: knock sensor (blk crx)
What ECU are you using?
Did you wire up knock sensor at all?
You need to wire up the one sensor to the D3 pinout, unless you switch to a chipped P28.
HTH
Old Jan 3, 2007 | 04:37 PM
blk crx's Avatar
Default Re: knock sensor (poison)
i'm running a p30 and using a rywire subharness
Old Mar 13, 2007 | 01:05 PM
No_xqcs's Avatar
Where is the knock sensor located on an eg6 b16a??
Old Mar 13, 2007 | 01:17 PM
Malakai's Avatar
back of the block i think.
crxb16ftw
May 20, 2007 10:31 PM
95redeg6
Apr 28, 2007 10:23 AM
93NXLUDE
Mar 5, 2003 06:32 PM
