FS: Benson Sleeved LS Block (assembled) and Built GSR Head
Old Jan 3, 2007 | 04:03 PM
B18 CYA's Avatar
Default FS: Benson Sleeved LS Block (assembled) and Built GSR Head
$2150 for the block setup...
B18A1 LS Block
84mm Benson Sleeves
84mm Wiseco 8.2:1 Coated Pistons
Eagle 3/8" (stronger) H-Beam Rods
ARP Head Studs
ARP Rod Bolts
ARP Main Studs
ACL Bearings
Aftermarket Girdle
LS Crankshaft
Comes with GSR Oil pump and water pump as well.
May be missing a few things. Built by the man uncivilizedmb (Derrick) . He is a local engine builder here and has one of the best reps for hondas here. I can provide a link to a local forum for vouches if needed. This motor has about 6000 kms on it if that (about 4000miles). I've had quite a bit of downtime this year with my car and didn't really drive it as much as I wanted to because of many things going such as fuel pump, turbo taking a ****, halfshaft, etc. Never had a problem with the motor at all.
Was mainly driven on 15psi making 355whp. Had it at the track at 21psi making 424whp and ran an 11.3 @ 128mph. I took the head off already and the pistons and cylinder walls still look minty. Compression test was done before the head was taken off and it was 160-165 across the board.
Here is the day after it was built:
Also for sale is a built GSR Head.
Portflow Valvesprings
Portflow Titanium Retainers
Skunk2 Stainless Steel Valves
GSR Cams
Mugen Valvecover (replica)
$1050 for the head
If you have any questions, don't hesitate to ask. :cheers
Can get pictures of both as it sits right now when I get the chance to.
Modified by B18 CYA at 1:00 AM 1/21/2007
Old Jan 4, 2007 | 09:09 AM
B18 CYA's Avatar
bump
Old Jan 5, 2007 | 10:01 AM
B18 CYA's Avatar
bump
Old Jan 7, 2007 | 12:53 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: FS: Benson Sleeved LS Block (assembled) and Built GSR Head (B18 CYA)
bump for a nice guy with quality parts
Get some new pics up!
Old Jan 15, 2007 | 05:09 PM
B18 CYA's Avatar
Damnit its like -40 degrees celcious here. Can barely stand outside without freezing. Motor is in the garage. I'll try and get recent pics soon once its warmer outside.
BUMP
Old Jan 16, 2007 | 08:41 AM
B18 CYA's Avatar
Default Re: (B18 CYA)
bump. open to offers
Old Jan 20, 2007 | 04:00 PM
B18 CYA's Avatar
bump. 2150 for the block?
Old Feb 3, 2007 | 02:22 PM
B18 CYA's Avatar
bump
Old Feb 4, 2007 | 10:37 AM
PM me your number
jmoney45
Aug 25, 2009 01:33 PM
B18 CYA
Dec 19, 2006 03:50 PM
H.A.R.T B18C1EG6
Mar 22, 2006 10:26 PM
H.A.R.T B18C1EG6
Mar 1, 2006 03:21 PM
