b18c1 arp head stud tq specs?
the paper that came with the studs says torque it 65ftlb with the lube that comes with it. ive searched the net and ppl came up with diffrent specs? any one know the correct one?
Lets see.....sheet of paper from ARP or people who have probably never owned a set of ARPs....which one should I trust??? Do it in a 2 step process, first step to 22ish, second step to 63/65.
torque specs are dependant on the type of lubricant you use. ARP reccomends torque specs with their moly lube they supply with the fasteners. IF people are using another torque spec, its probably for use with oil
