1 or 2 fuel filters and where? SEARCHED
i drive a (sig) and it bogs occasionaly on the freeway when i have less than a quarter tank...I am guessing its the filters but my neighbor said i only had one... so back to the title...how many and where are they located?
take out back seat, theres a silver pan on the floor, take it off and the rest is pretty self explanitory, im not sure where you'd get a replacement sock though, good luck, if you really are uneasy about it, search for a artical on replacing your fuel pump.
imagine taking your rear seat out, undoing a few screws in the floorboard, lifting the fuel pump out, popping the sock filter off and popping the new one back on, putting the fuel pump back in, put ur screws back in, put your seat back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">i didnt know there was a filter around the fuel pump im curiosu 2 know about this? how much does one of those cost to replace?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">okay well im going to go to a honda dlr tomorrow and get the sock...and is it reccomended that you change em---and how much do u think they r money wise$?</TD></TR></TABLE>
BUMP
BUMP
go to ur local parts store. a soc shouldnt cost more then 10 bux and the fuel filter should cost around 15-20 bux. the rear sock is simple to change., i changed my fuel pump in less then an hour, the sock shouldnt take u longer then that unless u do something retarded and break something or just dont have the tools
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">how in the hell do you pull the fuel pump out?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">take out back seat, theres a silver pan on the floor, take it off and the rest is pretty self explanitory, im not sure where you'd get a replacement sock though, good luck, if you really are uneasy about it, search for a artical on replacing your fuel pump.</TD></TR></TABLE>
When you actually pull the pump out itself, try to be careful. You have to slide is sideways sort of.
edit: found this
https://honda-tech.com/zerothread?id=1572312
edit: found this
BOOSTWERKS
Mid-Atlantic (Sales)
Jan 5, 2009 06:08 AM
The_In_Kid
May 15, 2002 12:33 PM
