o2 sensor.
Old Jan 3, 2007 | 12:31 PM
adobospoon's Avatar
Default o2 sensor.
Needing help. I have a 5 wire o2 sensor that needs to be changed to a 4 wire. My question is can i repin the 4 wire into the 5 wire harness where the o2 disconnects. Because I did a swap from a d15z1 to a d15b and need to run a 4 wire. So if anybody has done this. What wires did you repin on that harness. Thanks. Real new to this.
Old Jan 3, 2007 | 12:40 PM
adobospoon's Avatar
Default Re: o2 sensor. (adobospoon)
anybody?!?!?!
Old Jan 3, 2007 | 12:56 PM
adobospoon's Avatar
nobody!?!?!
Old Jan 3, 2007 | 05:14 PM
adobospoon's Avatar
Please. Needing help!!!
Old Jan 3, 2007 | 05:29 PM
adobospoon's Avatar
anybody???
Old Jan 3, 2007 | 05:30 PM
allricedout's Avatar
are you wanting to know which one to cut?
Old Jan 3, 2007 | 05:38 PM
adobospoon's Avatar
Default Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">are you wanting to know which one to cut?</TD></TR></TABLE>well basically im not chopping nothing just talking out the old 5 wire o2 from the old harnesa and repinning the wire to the old 5 wire harness. What im looking for is what 2 wires do i connect i know the other two are ground
Old Jan 3, 2007 | 07:38 PM
adobospoon's Avatar
Default Re: (adobospoon)
anyone else!?!?!
Old Jan 3, 2007 | 08:10 PM
adobospoon's Avatar
bumpitybump
Old Jan 3, 2007 | 08:33 PM
adobospoon's Avatar
has anybody convert a 5 wire o2 sensor to a 4 wire o2 sensor on a vx Let me know ASAP
Old Jan 4, 2007 | 11:01 AM
specv5150's Avatar
https://honda-tech.com/zerothread?id=295330
That might help.
I couldnt find the thread i used.
I basically bought a Helms and located the colors of the wires on my 5 wire and what they did. Then did the same thing for the 4wire. Worked perfectly. Of course this was on an HX and EX/LX/ so the wiring colrs WILL be different
Old Jan 4, 2007 | 06:59 PM
adobospoon's Avatar
Default Re: (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=295330
That might help.
I basically bought a Helms and located the colors of the wires on my 5 wire and what they did. Then did the same thing for the 4wire. Worked perfectly. Of course this was on an HX and EX/LX/ so the wiring colrs WILL be different</TD></TR></TABLE>
alright thanks bro. Just one more thing. can i still reuse my old harness from the 5 wire o2 sensor and just repin the 4 wire o2
slammedz6ef
Feb 15, 2008 07:46 AM
ef dino
Jul 5, 2007 07:04 PM
redflaredb1690
May 12, 2006 01:56 AM
monicle
Aug 23, 2003 07:30 AM
civicmatt
Jun 22, 2003 07:27 PM
