I need some wiring
So on saturday I am dropping a d16y8 into my hatch, it used to have a d16y7 in it. I got the p2p ecu for it, but I know there is a decent amount of wiring necessary. I don't really know **** for electronics and I was wondering if anyone knows of anybody in the area of york pa that could do this. or maybe someone has a really detailed step by step instruction guide that could keep me from ******* things up. I did get one picture, but I still need more. How many sensors need changed? Where do I put the wires into the ecu? Im ******* lost.
You're going to need:
-VTEC solenoid wiring
-VTEC pressure switch wiring
-Knock sensor wiring
-Convert your 3 wire IACV to 2 wire
-either reuse your Y7 exhaust manifold or run an O2 extension harness to the Y8's collector (because it goes from the manifold top to the collector before the cat)
Its not too hard, PM me if you need any advice
So then, am I using the plugs from the y7 or the y8? And I guess by you saying I need wiring that means I will have to figure out where to Solder? those onto the ecu? I am really doubting myself with this, and that's why I am asking a lot of questions
bennjamin@ozhonda.com
Sep 21, 2006 02:00 AM
