Hood lever
Old Jan 3, 2007 | 11:40 AM
EJ1Dream's Avatar
Default Hood lever
ight, so yesterday i poped my hood, and when i went to shut it, it kept not shooting so i tried kicking it shut, slamming it, the last time i tried closing it it went all the way down and latched., but now my hood lever is very loose and it isnt opening the hood. how can i go about fixing this problem? it doesnt seem broke or anything just seems like somehow theres too much slack in it. any help is greatly appreciated
Old Jan 3, 2007 | 11:46 AM
hatch92only's Avatar
maybe tighten the cable and or check out the lever hatch
Old Jan 3, 2007 | 11:49 AM
EJ1Dream's Avatar
Default Re: (hatch92only)
how do i tighten the lever... the only spot i can get to the cable is the latch under the dash.
Old Jan 3, 2007 | 12:01 PM
instructor74's Avatar
Default Re: (EJ1Dream)
This is a common problem with the 92-95 civic I don't know about other years. The lube on the latch assy gums up and the cable return spring can't pull the cable back. All that needs to be done is to degrease the latch assy relube it while a friend works the handle inside the car you might have to lube the cable right where it enters it covering. I sounds like you broke something when you forced the hood to close. You might have to open the hood from under the car and fix what ever got broken.
Old Jan 3, 2007 | 02:04 PM
instrument's Avatar
to re-open it try gently pressing down on the hood while someone else pulls the lever inside the car.
next time your hood won't latch, don't be a moron, you simply need to slide the lever back under the hood to reset it.
Old Jan 3, 2007 | 05:39 PM
EJ1Dream's Avatar
i tried all that when shutting the hood... personally its a little hood i could give 2 craps about it.. and im 99% sure i didnt break anything. but thanks for ur help everyone ill try it out tomorrow.
Old Jan 3, 2007 | 07:04 PM
2coupes's Avatar
mine does this, there's a little silver thing on the cable on the left side of the latch, push it back to the right near the latch and it'll shut everytime
efjones9
Jan 11, 2009 01:04 PM
ZCHF
31
Mar 15, 2004 06:20 PM
naterpatater77
Feb 29, 2004 05:32 PM
cannan
Dec 28, 2003 09:40 AM
