car runs like crap
Old Jan 3, 2007 | 10:48 AM
Bc1r6x's Avatar
Default car runs like crap
I pulled the codes on my car and it had: 5 MAP sensor, 13 BARO - atmospheric pressure sensor, 41 Primary oxygen sensor heater, 7 TPS - throttle position sensor
Im running a obd1 ecu with an obd0 engine... It falls on its face at cruse but if I give it some gas it dosen't studder at all... anybody got any clues... FYI I just put in an obd1 dizzy
Old Jan 3, 2007 | 10:53 AM
ludesrv's Avatar
Is the wiring correct?
First of all, fix the Map sensor. It's the reason the engine is running like poo. Then fix #13 and 7. They will help with stabilizing the engine. Code 41 just hurts gas mileage, everything else hurts the engine operation.
Don't be half ***, fix the codes before driving it.
FYI: The dizzy has nothing to do with any of your codes.
Old Jan 3, 2007 | 10:56 AM
STREETWERKZ's Avatar
Default Re: (ludesrv)
still running a 1 wire o2 sensor?
WTF.... this is a half-assed OBD-0 to OBD-1 conversion?
Old Jan 3, 2007 | 03:14 PM
Bc1r6x's Avatar
Default Re: (STREETWERKZ)
I used a boomslang harness so its not a shitty swap
Old Jan 3, 2007 | 03:22 PM
Default Re: (Bc1r6x)
ha.
" car runs like crap "
Old Jan 3, 2007 | 07:18 PM
Bc1r6x's Avatar
Look man I'm not here to take your **** I know what I'm doing but sometimes stuff goes over your head... So either help out or don't post on my topics
and btw I'm running a 4 wire O2 using a boomslang harness OBD1 dizzy with a pr3 ECU and I know what all the sensors do but the sensors don't always have to be replaced when that code is thrown so I'm going to use my multi meter and test some sensors.
theEG6
Dec 23, 2013 06:58 AM
BlueRex1020
Mar 17, 2007 09:28 PM
deftones0817
Sep 20, 2005 05:58 AM
pinoyboy204
Nov 2, 2003 07:06 PM
