Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
EM Racing Products
Old Jan 3, 2007 | 09:12 AM
Touge Tuning's Avatar
Default EM Racing Products
I am proud to accounce that I will be offering EM Racing products to all of you at great prices that you have come to expect from Touge Tuning. The way this will work is pricing will be based upon the total number of products ordered. The more I order the better pricing I can offer to you all. I will leave the list open for a few weeks or until I reach the maximum discount level and then the order will be placed. Prices listed are in US dollars and include general shipping, some areas may be slightly more but not much. Also if you order more than 1 product at a time subtract $6.50 for each additional product you order.
Tiers are based opon total order quantity not just of that specific piece but of all orders.
Tier 1: Under 10 total pieces ordered
Tier 2: 10-24 total pieces ordered
Tier 3: 25-49 total pieces ordered
Tier 4: 50+ total pieces ordered
Contact Info:
Chris Richardson
Sales@TougeTuning.com
(MSN) TougeTuning@hotmail.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
<u>C-Pillar Bars</u>
By tying the c-pillars together, the structural rigidity of the vehicle's chassis is reinforced, preventing the pillars from flexing under hard cornering.
- Approximate installation time: 5 mins
- Aircraft quality 6061
- T6 aluminum
- Significantly improves handling
- Bar stock disconnects in seconds: No Tools Required!
Fitments:
-88-91 CRX
-88-91 Civic HB*
-92-95 Civic HB**
-92-95 Civic 2dr/4dr
-96-00 HB
-92-96 Prelude**
-97-02 Prelude
-90-93 Integra 2dr
-94-01 Integra 2dr
Tier 1: $146
Tier 2: $134
Tier 3: Too Low to List, Contact for Pricing
Tier 4: Too Low to List, Contact for Pricing
-90-93 240sx HB***
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
Note: backseat and seatbelts may be left intact, but presence of backseat passengers is prohibited while bar is in place. Failure to comply may result in serious or fatal injury. Off road and race use only.
* Plastic surrounding seat belt mount must be trimmed for proper fitment (89-91 civic hatch only)
** Panel requires minor cutting for proper fitment for 92-95 Honda Civic HB.
***Models with black seatbelt box only. Sealtbelt assembly must be removed. No quick release option.</TD></TR></TABLE>
<u>Rear Strut Brace</u>
Ties the two rear opposing strut towers together as a single solid unit for increased chassis rigidtity and improved overall handling. Integrated on each strut brace mount are the brackets for the triangulated bars which make upgrading simple and painless.
- Approximate installation time: 10 mins
- Sturdy one piece brackets
- Straight across design: No 90 degree bends
- Adjustable pre-load to maintain desired camber settings
Fitments:
-88-91 CRX
-88-91 Civic HB
-92-95 Civic HB
-96-00 Civic HB
-96-00 Civic 2dr/4dr
-92-97 Del Sol
-90-93 Integra 2dr
-94-01 Integra 2dr
-94-01 Integra 4dr
Tier 1: $188
Tier 2: $176
-02+ Acura RSX
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
-03+ Lancer Evo VIII
Tier 1: $176
Tier 2: $165
Tier 3: $149
Tier 4: $143
-90-93 240sx HB
Tier 1: $176
Tier 2: $165
Tier 3: $149
Tier 4: $143
Note: Some paneling may require minor cutting for proper fitment
<u>Trunk Floor Bar</u>
A must for all cars from street to all out competition. This bar takes the twist and roll out of the sheet metal by connecting two solid points in the trunk floor.
- Utilizes factory tapped holes
- Adjustable ends makes installation simple
- Rod ends withstand over 12,000 lbs. of radial load
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-94-01 Integra 2dr
-94-01 Integra 4dr
Tier 1: $121
Tier 2: $113
-02+ Acura RSX
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
<u>Triangulated C-Pillar Bar:</u>
This addition triangulates the c-pillar tie bar and the rear strut tower brace, completing the four sided structure (see explanation page for details).
- First triangulated pillar bar in the market for the Integra and Civic
- Improvement is undeniable: You will FEEL a difference!
- Triangulated for maximum rigidity
Fitments:
-88-91 CRX
-88-91 Civic HB
-92-95 Civic HB
-96-00 Civic HB
-90-93 Integra 2dr
-94-01 Integra 2dr
Tier 1: $121
Tier 2: $113
-90-93 240sx HB
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
Note: Must be used in conjunction with rear strut tower bar and the c-pillar bar. Each sold separately. Rear passenger side seat must be folded forward for bar to fit in place for some models.
* Passenger side seatbelt can not be retained for 96-00 Honda Civic HB
<u>Triangulated Trunk Bar</u>
This addition triangulates the trunk floor bar and the rear strut tower brace, completing the four sided structure (see explanation page for details).
- First triangulated trunk bar in the market for the Integra and Civic
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-90-93 Integra 2dr
-94-01 Integra 2dr
-94-01 Integra 4dr
Tier 1: $116
Tier 2: $108
-02+ Acura RSX
Tier 1: $114
Tier 2: $107
Tier 3: $95
Tier 4: $86
Tier 1: $109
Tier 2: $102
Tier 3: $91
Tier 4: $80
Note: Must be used in conjunction with rear strut tower bar and trunk floor bar. each sold separately.
<u>Trunk Wall Brace:</u>
For all you DC2 owners, this bar installs where the OEM Type-R brace sits, but with a little added style. Made from high stiffness to weight ratio 6061-T6 aluminum, this upgrade prevents the brittle trunk wall from flexing.
- Approximate installation time: 30 mins
- Available in brushed aluminum
- Includes all necessary hardware
- Improves regular and hard driving conditions
Fitments:
-90-93 Integra 2dr
-94-01 Integra 2dr
Tier 1: $110
Tier 2: $101
Note: Plastic panel requires minor cutting for proper fitment. Some drilling is also required.
<u>Rear Lower Tie Bar</u>
Fitments:
-92-95 Civic HB
-96-00 Civic HB
-93-97 Del Sol
-90-93 Integra 2dr
-94-01 Integra 2dr
-94-01 Integra 4dr
Tier 1: $110
Tier 2: $101
<u>DRIVE Road Race Master Cylinder Brace</u>
Drive Road Race Products are designed for the hardcore enthusiast in mind. Clearly far superior in design and quality, this product was designed by Drive engineers to withstand the abuse put forth by extreme drivers.
The Master Cylinder Brace, made of 6061-T6 Aluminum billet, mounts onto the inboard side of the shock tower housing and prevents the brake master cylinder from moving forward (caused by flex in the firewall and brake booster) when excessive pressure is applied to the brakes under hard driving conditions, such as road racing and autocross. The overall result is a greatly improved brake feel and sensitivity, therefore reducing brake fade…even for everyday street use!! The brace comes with two M6 (10mm head) threaded bolts.
- Aircraft quality 6061-T6 aluminum
- Improves pedal feel
- Quick and easy installation
Fitments:
-92-95 Civic
-96-00 Civic
-94-01 Integra
Tier 1: $89
Tier 2: $82
Tier 3: $74
Modified by Stealth1 at 1:55 PM 1/3/2007
Old Jan 3, 2007 | 09:14 AM
1.Big Hairy Gino - 94-01 Integra 2dr C-pillar Bar
2.Big Hairy Gino - 94-01 Integra 2dr Rear Strut Brace
3.Big Hairy Gino - 94-01 Integra 2dr Triangulated Pillar Bar
Old Jan 4, 2007 | 07:19 AM
Bump
Old Jan 4, 2007 | 03:41 PM
1. Big Hairy Gino - 94-01 Integra 2dr C-pillar Bar
2. Big Hairy Gino - 94-01 Integra 2dr Rear Strut Brace
3. Big Hairy Gino - 94-01 Integra 2dr Triangulated Pillar Bar
4. ES - 94-01 Integra 2dr C-pillar Bar
5. ES - 94-01 Integra 2dr Rear Strut Brace
6. ES - 94-01 Integra 2dr Triangulated Pillar Bar
Old Jan 4, 2007 | 10:21 PM
KnowGood's Avatar
Default Re: EM Racing Products (Stealth1)
is there absolutly no ep love???
Old Jan 5, 2007 | 08:25 AM
racer22's Avatar
BUmp!!!!
GOOD STUFF!!
Old Jan 5, 2007 | 08:46 PM
Default Re: EM Racing Products (KnowGood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KnowGood &raquo;</TD></TR><TR><TD CLASS="quote">is there absolutly no ep love???</TD></TR></TABLE>
Unfortunately not at the moment, im sure if you email EM they will definitely consider it
Old Jan 5, 2007 | 09:23 PM
7. Buff4Prez Yo - 90-93 Integra 2dr C-pillar Bar
8. Buff4Prez Yo - 90-93 Integra 2dr Rear Strut Brace
9. Buff4Prez Yo - 90-93 Integra 2dr Triangulated Pillar Bar
Old Jan 8, 2007 | 07:59 AM
We are in Tier 2 pricing now
10.TypeRLegend - 94-01 Integra 2dr C-pillar Bar
Old Jan 8, 2007 | 05:34 PM
Bump
Old Jan 9, 2007 | 01:58 PM
Thanks for the interest everyone
Old Jan 10, 2007 | 07:08 PM
TTT
Old Jan 12, 2007 | 10:20 PM
keep the pm's coming
Old Jan 15, 2007 | 06:27 AM
Up for some of the most high quality bars on the market.
Old Jan 15, 2007 | 09:09 PM
joe_bocc's Avatar
Default Re: (Stealth1)
Bump. Come on people, lets get to tier 4. I want to be able to eat lunch lol.
Old Jan 18, 2007 | 11:09 AM
Back from vacation now
Old Jan 18, 2007 | 09:54 PM
11.joe_bocc - 92-95 Civic hatchback C-pillar Bar
12.joe_bocc - 96-00 Civic hatchback C-pillar Bar
13.joe_bocc - 96-00 Civic hatchback trunk floor brace
14.joe_bocc - 94-01 Integra 2dr Trunk wall brace
Old Jan 19, 2007 | 10:38 AM
ef8 h0!'s Avatar
do pricing on whole kits?
Old Jan 19, 2007 | 08:30 PM
Lets get to tier 3 atleast :D
Old Jan 20, 2007 | 12:24 AM
99SlammedCivic's Avatar
Snipper Snapper
Pm'd !
Old Jan 20, 2007 | 06:32 AM
Replied
Old Jan 21, 2007 | 07:18 PM
15.Dan - 02+ RSX Triangulated Trunk Bar
16.Dan - 02+ RSX Trunk Floor Bar
17.Dan - 02+ RSX Rear Strut Brace
Old Jan 22, 2007 | 08:02 AM
18.aVstAr - CRX C-Pillar Bar
19.aVstAr - CRX Rear Strut Brace
20.aVstAr - CRX Triangulated Pillar Bar
Old Jan 24, 2007 | 09:00 AM
Tier 3 pricing is now a go!!!!
Old Jan 24, 2007 | 02:23 PM
00jdmsi's Avatar
