ecu code 43 ???
Old Jan 3, 2007 | 08:06 AM
RA61825's Avatar
Default ecu code 43 ???
hey guys goodmorning , i was wondering if any can help with a code 43, i dont know what can be wrong, i know its fuel supply. any help will be appreciated
Old Jan 3, 2007 | 09:17 AM
JT2MA71's Avatar
Not seeing a 43 in my book or the online manual I often reference. Could be a 4 and a 3. These would definitely mess with your fuel and timing.
Code 4 is the crank angle sensor. if you're sohc, it's in the distributor. if you have a dohc zc, it is the sensor on the exhaust cam.
http://media.honda.co.uk/car/o...2.pdf
Code 3 is manifold absolute pressure, so look into the MAP sensor on the firewall.
http://media.honda.co.uk/car/o...6.pdf
Hopefully these pages help. Good luck.
Old Jan 3, 2007 | 09:59 AM
oodie's Avatar
Default Re: ecu code 43 ??? (RACERX72)
Is the car in safe mode?
Old Jan 3, 2007 | 10:02 AM
em Dot's Avatar
POOPCheeks
Default Re: ecu code 43 ??? (oodie)
i had that too when i ran a integra ecu in my stock crx si. i think its something about not getting enough fuel or something. not positive on what it was.
Old Jan 3, 2007 | 10:07 AM
89efDUSTY's Avatar
Default Re: ecu code 43 ??? (em Dot)
pretty sure it is 4 & 3
Old Jan 3, 2007 | 10:14 AM
RA61825's Avatar
Default Re: ecu code 43 ??? (89efDUSTY)
no guys its 43 man im running a p28 ecu on a 94 zcvtec motor, im just trying to find out, 43=fuel supply
Old Jan 3, 2007 | 11:18 AM
JT2MA71's Avatar
Probably would have helped to say that in your orignal post...lol. I figured since you didn't say otherwise, you had a si/zc variant using a stock or similar ecu.
Old Jan 3, 2007 | 11:28 AM
em Dot's Avatar
POOPCheeks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure it is 4 & 3 </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">
here is a pic of the Jumper to check the codes
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Modified by JDMlyfestyle at 11:58 PM 11/24/2005</TD></TR></TABLE>
come on guys. back on track there is a code 43.
also RACERX72, does the code go away for a while(like a week or two) then out of nowhere it comes back?
Old Jan 3, 2007 | 05:36 PM
RA61825's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em Dot &raquo;</TD></TR><TR><TD CLASS="quote">come on guys. back on track there is a code 43.
also RACERX72, does the code go away for a while(like a week or two) then out of nowhere it comes back?</TD></TR></TABLE>
no i just noticed it today man ima keep looknig at it for a few days thnx em dot, i knew it was a 43
ohgodbadname
11
Oct 29, 2012 07:24 PM
driftam1
Oct 27, 2008 03:21 PM
lscrxhf
Jul 4, 2006 08:08 AM
igone94integra
Sep 28, 2003 07:28 PM
.brad
Feb 26, 2002 03:30 AM
