Rattling inside engine.
Old Jan 3, 2007 | 05:41 AM
redLUDEs2k1's Avatar
Default Rattling inside engine.
I have a 2002 RSX type S. When i get to just about 2500 rpm, there is a rattling/vibration noise coming from the engine area. The noise tapers off around 3000 rpm, and is not heard below or above these rpms. Also, after the car is warmed up, a lighter rattling noise can be heard at idle, which sounds as if it is coming from the transmission. What could this be?
Old Jan 3, 2007 | 07:43 AM
f1nal zeros's Avatar
The noise is coming from the valve cover plate.
The item that says "Ivtec" on it.
Its been known to come loose after time.
Just get a 10mm and tighten the 2 bolts up and you should be fine.
Old Jan 3, 2007 | 11:16 AM
dc5tegk20's Avatar
around the time you here this is when the VTC kicks in in I-vtec my car makes the same noise
Old Jan 8, 2007 | 04:52 PM
CASTUDILLO01's Avatar
Default Re: Rattling inside engine. (redLUDEs2k1)
MAY WANT TO CHECK OUT THE EHAUST SHEILD ABOVE THA AXLE. I WORK AT A ACURA DEALER AND COMMON NOISE THAT RSX HAVE ARE THE RIGHT AXLE HEAT SHEILD..
Old Jan 8, 2007 | 07:07 PM
swollen_cu's Avatar
Default Re: Rattling inside engine. (CASTUDILLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">MAY WANT TO CHECK OUT THE EHAUST SHEILD ABOVE THA AXLE. I WORK AT A ACURA DEALER AND COMMON NOISE THAT RSX HAVE ARE THE RIGHT AXLE HEAT SHEILD..</TD></TR></TABLE>
+1 on taht one man! i have a 2006 type s and i had hte same problem. i jsut took it off cause it wouldnt stay tight
SIDreamer
Feb 25, 2011 09:28 PM
FSBxtreme
Dec 8, 2007 12:18 PM
suken19
Jul 31, 2007 04:59 PM
A is 4 PiMp
Sep 29, 2006 07:29 PM
ghettols
14
Aug 15, 2003 12:52 PM
