Re-wiring/Tapping into-side markers.
How do re-wire my sidemarkers to not turn on while my lights are on and only turn on when my blinkers are on? ALSO, how do I get to those wires to do the trick?
Re-wire to your blinker, to eazy...Find your blinker wires, cut them, then join the side marker and blinkers together!
Could I do all this just by finding the blinker light wires from inside the dash? THen finding and mating the side marker wires with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA (H) TEG »</TD></TR><TR><TD CLASS="quote">Could I do all this just by finding the blinker light wires from inside the dash? THen finding and mating the side marker wires with it?</TD></TR></TABLE>
Not really, no. There's no reason to try to run the side marker wired through the firewall into the passenger compartment. You shouldn't have any trouble locating them at each corner of the front bumper. Also, if you don't want to cut and splice, you can pick up some snap-on splice connectors to simplify things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Not really, no. There's no reason to try to run the side marker wired through the firewall into the passenger compartment. You shouldn't have any trouble locating them at each corner of the front bumper. Also, if you don't want to cut and splice, you can pick up some snap-on splice connectors to simplify things. </TD></TR></TABLE>
Got it,
Thank you.
Got it,
Thank you.
