Radiator Help
Old Jan 2, 2007 | 08:01 PM
robble36's Avatar
Default Radiator Help
i own an Ek4 with a JDM b18C type R looking forward to buying a new radiator either fluidyne or Koyo the problem is i dont know whether to buy it for the ENGINE or the CAR MODEL sorry if this is a stupid / noob question but it really stumps me i mean it makes sense to get the radiator made for the model because if i get the 96-00 model that means it is made to fit in my car but if you dont get it based on the motor how will it function the same?
Old Jan 2, 2007 | 08:04 PM
RCautoworks's Avatar
Default Re: Radiator Help (robble36)
92-00 radiators are pretty much the same, buy it for the model of your car though. And unless you just are doing it for looks, 99% of the time those type of radiators are not even needed.
Old Jan 3, 2007 | 01:13 PM
robble36's Avatar
thanks i am currently just running stock radiator with 2 fans i like how the koyo or fluidyne ones are they are the half sized ones it looks better and it would give my headers space
Old Jan 3, 2007 | 01:18 PM
GSaura's Avatar
I believe that the model Koyo you need is R1570 for 92-00 civic with B-series swaps. Ask Marty at injected performance to make sure. I just put one of these in my 95 coupe with GSR motor. The radiator fits snugly. The clearance between the slave cylinder and the fan housing is diminished but acceptable. The stock fan shroud has to be modified to fit on the radiator. Make sure you pick up a cap when you order the radiator.
https://honda-tech.com/zerothread?id=1812339
Jeremy Pollok
Mar 3, 2016 02:38 PM
ITRICED
Oct 23, 2008 05:15 PM
Flipnotize21
Honda Civic (2006 - 2015)
Nov 6, 2006 12:16 PM
Dartanian
Jun 13, 2006 09:37 PM
