Need Oil Restrictor for turbo....
Old Jan 2, 2007 | 06:41 PM
TurbodTegSfaria's Avatar
Default Need Oil Restrictor for turbo....
ive heard of guys running an oil restictor to the turbo, now can someone tell me where or how to make one of these things..thanks
Old Jan 2, 2007 | 06:45 PM
Mugencrxsir1's Avatar
Default Re: Need Oil Restrictor for turbo.... (TurbodTegSfaria)
turbonetics sells them with every turbo they make/sell, so call their parts department/turbo accessories. They can get you one and I think ATP has them as well, just google oil restrictor and you'll be suprised with the hits.
Old Jan 2, 2007 | 08:46 PM
Sprockets's Avatar
I bought a male to female stainless 1/8" NPT .035" restrictor that won't fit my turbo. If you can use this, let me know. I'll let it go for less than I paid. Also, it would be easy to enlarge the orifice if it's too small for you.
Old Jan 2, 2007 | 08:48 PM
ryan89crx's Avatar
ATP sells them for cheap
i run a Function7, a little more spendy but i like it
Old Jan 2, 2007 | 10:08 PM
littletriad's Avatar
any links for these places
Old Jan 3, 2007 | 05:03 AM
akira712's Avatar
Default Re: (littletriad)
http://www.mcmaster.com/
part # 2712T44
http://www.wicksaircraft.com/c...75089
a few of the less expensive one ive found
or you could just weld shut a fitting and drill it out for your needs
~.065 restrictor for T series non ball bearing turbos and ~.035 restrictor for BB turbos
I just took a fitting tapped it and then screwed in a plug used some locktite and drilled it out.
Old Jan 3, 2007 | 06:04 AM
splitime's Avatar
Default Re: (eastcoast_ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej &raquo;</TD></TR><TR><TD CLASS="quote">
I use that one and just drill it out a hair. Has worked fine and was the cheapest I found online.
Old Jan 3, 2007 | 08:32 AM
SIXTY-1HATCH's Avatar
Default Re: (splitime)
If you have the right feed line you don't need a restrictor -3 line and your good to go!!!
garrett factories and distributors will tell you the same if it's -4 then yea youll need a small one.
SAXON
Sep 18, 2010 12:53 AM
nicktagz
Sep 10, 2006 07:38 PM
delsoldrew
Sep 4, 2006 12:56 PM
JM Performance
Sep 16, 2001 11:52 PM
