need help,car wont run
Old Jan 2, 2007 | 03:28 PM
red beast's Avatar
Default need help,car wont run
swapped 92 ls in 96 civic coupe,bolt on include intake manifold,throttle body,450 dsm injectors,bdl fuel rail,fuel pressure regulator,i used back my stock wire harness the only thing i did was change the injector plugs. started the car with stock computer,and a couple more,but the car is running rich,it wont rev out and idle real bad
Old Jan 2, 2007 | 03:51 PM
jfruauff's Avatar
Default Re: need help,car wont run (red beast)
OK. Its the injectors. Did you install a resistor pack because you need to to run dsms. Its gonna run really rich them injectors are twice the size of stockers.
Check the wiring...
Old Jan 2, 2007 | 03:59 PM
red beast's Avatar
Default Re: need help,car wont run (jfruauff)
i have resistor pack, but i did not put it in because i was told i dont need it. that it for turbo
Old Jan 2, 2007 | 05:04 PM
jfruauff's Avatar
I am pretty sure you do. Like 95% sure
Old Jan 3, 2007 | 06:58 PM
red beast's Avatar
install resistor pack today , car runs better . what commputer should i use
Old Jan 4, 2007 | 03:57 PM
jfruauff's Avatar
the stock ls is fine. you need to pull some fuel your running super rich..
turboacurab20
Engine Management and Tuning
Mar 16, 2011 08:57 AM
ocracing973
Nov 7, 2009 04:34 AM
ashb82
16
Dec 18, 2008 05:34 PM
eglslsd
Jun 22, 2007 06:00 PM
