need help,car wont run
swapped 92 ls in 96 civic coupe,bolt on include intake manifold,throttle body,450 dsm injectors,bdl fuel rail,fuel pressure regulator,i used back my stock wire harness the only thing i did was change the injector plugs. started the car with stock computer,and a couple more,but the car is running rich,it wont rev out and idle real bad
Re: need help,car wont run (red beast)
OK. Its the injectors. Did you install a resistor pack because you need to to run dsms. Its gonna run really rich them injectors are twice the size of stockers.
Check the wiring...
Check the wiring...
ocracing973
Engine Management and Tuning
11-07-2009 04:34 AM
paulzy
05-16-2002 08:59 PM
