TIMEING BELT HELP!!!!... in process right now!!!!
Old Jan 2, 2007 | 03:04 PM
SpOoLiNg CiViC's Avatar
Default TIMEING BELT HELP!!!!... in process right now!!!!
ok! i have all the cover off and i have car jacked up. i have a impact trying to take the 17mm nut off the crank pully and it is not wanting to un tighten. the engine keep spinning. i put it in gear.... is it right handed or left handed thread? i just cant seem to break the bolt hold..... help!!!!!!!
Old Jan 2, 2007 | 03:09 PM
Neebs's Avatar
Default Re: TIMEING BELT HELP!!!!... in process right now!!!! (SpOoLiNg CiViC)
are you holding the flywheel? the bolt tread should be standard btw.
Old Jan 2, 2007 | 03:10 PM
verycleanhatch's Avatar
you need a crank pulley tool. to keep the pulley from moving.
Old Jan 2, 2007 | 03:11 PM
Neebs's Avatar
Default Re: TIMEING BELT HELP!!!!... in process right now!!!! (verycleanhatch)
^ is it the chain wrench?
Old Jan 2, 2007 | 05:13 PM
Default Re: TIMEING BELT HELP!!!!... in process right now!!!! (Neebs)
no but you can use a chain wrench too. the crank pulley is a specifically designed tool to hold the pulley in place while you unbolt it.
it is like a socket with a extra piece so you can a attach a wrench to it while still having access to the bolt the hold the pulley.
zeroptzero
Jan 6, 2019 07:24 PM
mhernandez
16
Jul 10, 2012 07:53 PM
jdmed3
13
Mar 9, 2009 08:40 AM
omeara7
May 3, 2004 09:11 PM
xrocket21
Jun 4, 2003 04:35 PM
