Turn Signals as Driving lights
I have a 94 honda accord. And i wanted to know if there was a way to wire the turn signals on the front bumper to come on with the side marker lights and headlights, but still act as a turn signal? If anyone knows a way plz let me know. thanks
But couldn't you just wire it up to the same line as the turn signal bulb thats on the corner? That comes on nomral and then flashes. That bulb just has a flasher relay on one end that turns on and off the power going to it. So would it be possible to wire the turn signal bulb up to the corner bulb that flashes? And make it flash that way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnAcCoRd02 »</TD></TR><TR><TD CLASS="quote">you need to find two civic turn signal harnesses & bulb holders to make this trick work</TD></TR></TABLE>
Did this on my cb7...worked great!
Just get some 96-00 civic sockets and cut out your bulb socket and wire in the new one (red to red etc etc) and wire the 3rd light to the "hot" side of the corner lamp.
done
done
B18c5__Owns
Jan 23, 2008 03:55 PM
