endlink removal
Yup, that threaded bolt is hollow on the inside, it accepts an allen/hex key ( I dont know what size, looks like rust is gong to make it difficult anyway) and then use an open end or box wrench or one of those new geared wrenches to take it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_Si-R »</TD></TR><TR><TD CLASS="quote">I'm planning on buying new links but I can't even get these off</TD></TR></TABLE>
Cut it.
Cut it.
Drive an easy out into the open hole it might gice you the bite you need to get the nut off. If it still will not come off use a saws all or grinding wheel to cut it off
It's real easy. Between the boot and the LCA there is a round "ledge". Get a good set of pliars (I used RoboGrip pliers because they're thin and grip hard) and grab hold of that ledge. Then using the appropriate socket loosen the nut.
Since you have a lot of rust it's a good idea to soak the nut with PBBlaster about 1/2 hour beforehand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">
Cut it.
I second that, cut/drill them out, it was the only way I got mine off... And if you think that is hard, try putting those OEM ones on, when you have to tighten it with nothing to hold on the other side..... my do-over would be non OEM
Cut it.
</TD></TR></TABLE>I second that, cut/drill them out, it was the only way I got mine off... And if you think that is hard, try putting those OEM ones on, when you have to tighten it with nothing to hold on the other side..... my do-over would be non OEM
aimbot
Aug 7, 2008 03:03 PM
maynards_ek
Dec 25, 2007 06:45 PM
truevietluv636
11
Jun 6, 2007 07:13 AM
Dai_Ca_Vietnam_H22a4
Feb 9, 2006 02:09 PM
