Throw-Out Bearing.
Old Jan 2, 2007 | 11:56 AM
JDM_Frijoles's Avatar
Default Throw-Out Bearing.
I know how to change the damn thing but is there a different bearing that will withstand the beating. My trans right now has an Exedy unit and went bad a couple of weeks ago. Is it true that the bearing can *** the trans up if you dont change it promptly? Thanks in advance.
Old Jan 2, 2007 | 12:00 PM
BauleyCivic's Avatar
Risky Business
Default Re: Throw-Out Bearing. (JDM_Frijoles)
How do you know it's the throwout bearing and not a bearing inside the transmission?
Old Jan 2, 2007 | 12:04 PM
Default Re: Throw-Out Bearing. (BauleyCivic)
When i press the clutch in the sound goes away.
Old Jan 2, 2007 | 12:05 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote">When i press the clutch in the sound goes away.</TD></TR></TABLE>
That would be input shaft bearing, retard.
https://honda-tech.com/zerothread?id=596873 have fun. And i'll get the pictures back up eventually.
Old Jan 2, 2007 | 12:11 PM
[QUOTE=BauleyCivic]That would be input shaft bearing, retard.QUOTE]
Whats with the name calling? Common misconception, im just going by what like 5 people told me, thanks anyway.
Old Apr 9, 2007 | 06:40 AM
crexer's Avatar
buddy of mine used the exedy clutch kit with 7.5 lb flywheel and stage 1 clutch, the crappy throw out bearing in their package broke after 3k miles of use. One of the ears on the bearing that the spring clip goes into broke off. I would only use oem bearings
Old Apr 9, 2007 | 06:49 AM
pdiggitydogg's Avatar
wtf...why was this bumped?
Old Apr 9, 2007 | 07:26 AM
d357r0y's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">wtf...why was this bumped?</TD></TR></TABLE>
Good question
Old Apr 9, 2007 | 07:37 AM
ha.ha.ha...
Old Apr 9, 2007 | 07:56 AM
94Hatchd15b7's Avatar
When a throw out bearing starts to go bad it will make an anoying sound. Usually it will only make the sound when it is cold out. Like you said the noise goes away when you push the clutch pedal in. I have worked on many differnet cars and trucks that the owner tells me that there is a grinding noise coming from the transmission it is most likely the trow out bearing.
Old Apr 9, 2007 | 07:59 AM
actually...thats wrong
bad throw out makes the sound when the clutch is pressed...goes away when not
civic ef
May 29, 2012 01:02 AM
ether.real
Oct 7, 2009 06:49 PM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
Eklsv-t
Aug 28, 2008 10:52 AM
b18c eJ1
Mar 17, 2007 12:25 AM
