Need a new dizzy?
Old Jan 2, 2007 | 09:24 AM
E_F_9's Avatar
Default Need a new dizzy?
I had been throwing a code for the TDC sensor for about a week and it would turn off and not start for like 2 minutes a couple of times.A couple of days ago i was driving and it just turned off,backfired and then then stopped.It didnt sputter or anything.Pulled over and tried to start it every now and then for about 30 min.All it wants to do is sputter and backfire when i try to start it.Its getting fuel and spark.Any ideas?
Modified by E_F_9 at 10:45 AM 1/2/2007
Old Jan 2, 2007 | 09:46 AM
E_F_9's Avatar
The ecu was reset and no codes are showing
Old Jan 2, 2007 | 09:54 AM
kelchyn's Avatar
Default Re: (E_F_9)
have you checked the distributor yet?
Mine just quit on me last week as well, checked the distributor and apparently the bearing was on it's way out, ended up melting the rotor off the shaft.
Old Jan 2, 2007 | 09:57 AM
E_F_9's Avatar
Well a friend is going to let me use his to see if mine is bad.
Old Jan 2, 2007 | 10:04 AM
crx_pimp's Avatar
Default Re: Need a new dizzy? (E_F_9)
replace that dizzy! I've seen that problem alot before
Old Jan 2, 2007 | 10:48 AM
E_F_9's Avatar
Well pulled the cap off and the screw that goes through rotor to hold it on the shaft wasnt even in it,it was stuck to a magnetic part.So i put it where it was supposed to go and back together now,so im gonna put it back on and see what happens
Old Jan 2, 2007 | 11:00 AM
E_F_9's Avatar
Got it back together and it starts but wont rev very high and has a code for CPS.
Old Jan 2, 2007 | 11:58 AM
gsxr1k05's Avatar
time for a new dizzy
Old Jan 2, 2007 | 12:43 PM
E_F_9's Avatar
Yeah im going to get another one soon
SLIM NOTHING
Sep 8, 2010 09:37 AM
enjoi1104
Apr 11, 2009 06:05 PM
trooper0641
Jul 25, 2005 12:03 PM
TiggsCRX
15
Mar 21, 2004 04:00 AM
eknine
Jul 28, 2003 08:02 PM
