has anyone done a 2000 si clutch install?
Old Jan 2, 2007 | 06:41 AM
mikeycivic's Avatar
Default has anyone done a 2000 si clutch install?
Is anyone real familiar with this project?
Old Jan 2, 2007 | 06:44 AM
wrx'n you's Avatar
Default Re: has anyone done a 2000 si clutch install? (mikeycivic)
Old Jan 2, 2007 | 06:55 AM
mikeycivic's Avatar
Default Re: has anyone done a 2000 si clutch install? (projEKt B)
Old Jan 2, 2007 | 06:57 AM
Syndacate's Avatar
TONS of people are familiar with B16 clutch swaps...
What do you need help with?
Old Jan 2, 2007 | 07:08 AM
mikeycivic's Avatar
Default Re: (Syndacate)
I cant get the 19mm bolt above the starter to go all the way in the block
Old Jan 2, 2007 | 07:19 AM
Syndacate's Avatar
Default Re: (mikeycivic)
Are you using the same bolt that you took out? Is it in the same location? That bolt's longer than the rest. (or the bolt that goes there)
Check and compare the lengths of the other ones...
Old Jan 2, 2007 | 07:23 AM
mikeycivic's Avatar
well there are only a couple 19mm, I think 3 and I can get it about 3/4 in and it gets really hard to tighten and I am affriad of snapping or stripping it.
Old Jan 2, 2007 | 07:28 AM
Luserkid's Avatar
Theres 2 19mm bolts that go into the bracket holding the trans in on the back. The rest (that hold the trans) are 17mm.
Old Jan 2, 2007 | 07:29 AM
mikeycivic's Avatar
Default Re: (Luserkid)
no there is a 19 mm that goes above the starter
Old Jan 2, 2007 | 07:33 AM
EE_Chris's Avatar
Like Syndacate said, the two bolts that hold the starter against the trans - one is actually longer than the other because it goes through the trans and into the block. Hopefully you're not putting the longer bolt into the shorter bolt hole.
Past that, I got nothing. Never seen someone with this 'problem'.
Old Jan 2, 2007 | 07:36 AM
mikeycivic's Avatar
Default Re: (EE_Chris)
I know which bolts you are talking about but this is a bolt for trans to block. Its above the starter. There are 3 17mm and 1 19mm the 19mm is kinda below the head.
Old Jan 2, 2007 | 07:41 AM
mikeycivic's Avatar
this one
Old Jan 2, 2007 | 07:47 AM
blackdelslo's Avatar
Your link is taking FOREVER to load... maybe try just posting the image on the forum?
Old Jan 2, 2007 | 07:50 AM
mikeycivic's Avatar
Default Re: (blackdelslo)
yeah i know its not working how do I post a pic on here
Old Jan 2, 2007 | 07:52 AM
MasterKwan's Avatar
You're Fing up if you're putting a honda bolt into that hole with a 19 mm head on it. I just threw a socket on that bolt on my car and it's 17 mm for sure. Sounds like you're throwing the rear motor mount to tranny bolt in that hole. The pic doesn't even show the bolt but, it's the one right below the dizzy. I have a handful in my junk box so, I know it pretty well.
Old Jan 2, 2007 | 07:53 AM
mikeycivic's Avatar
http://www.honda-acura.net/diy...8.jpg
Old Jan 2, 2007 | 07:54 AM
mikeycivic's Avatar
well if I put the 17 in the hole it slides right in soooo 17mm is too small, how do you get pics on this damn thing?
Old Jan 2, 2007 | 07:59 AM
EE_Chris's Avatar
You have to have the pic hosted somewhere on the web...not on your desktop PC.
When you've got that done, click the little image button above (Bold, Italic, Underline, Link, Pic). You need to put the link between those IMG tags.
Old Jan 2, 2007 | 08:01 AM
mikeycivic's Avatar
well its from a diy that you can access through honda-acura.net
Old Jan 2, 2007 | 08:02 AM
mikeycivic's Avatar
copy my shortcut and paste it in a IE
Old Jan 2, 2007 | 08:22 AM
EE_Chris's Avatar
sigh...
Old Jan 2, 2007 | 08:23 AM
MasterKwan's Avatar
It may go all the way in because you already stripped out the threads that were there for the 17 mm bolt. If you stuck that 19mm bolt in there and cranked on it hard, the threads are probably done AND you might crack the block.
10 people have told you it's not a 19mm. If you want to check, go to Majestic honda and compare the part numbers to the bolts. You'll see the one under the dizzy and the one under the vtec solenoid are identical.
If the 19mm one that pic is pointing at is the tranny to rear mount bracked bolt, it's 17mm too.
Modified by MasterKwan at 9:33 AM 1/2/2007
Old Jan 2, 2007 | 08:26 AM
mikeycivic's Avatar
Default Re: (MasterKwan)
I understand what you guys are saying, it only got super hard when the bolt got about 3/4 in nad I pulled it back out and the threads are good on the bolt. It would take a lot to fors a 19 into a 17 and I am not that dumb. I am going to re look at it today. Its not making sense to me as well as all of you, thanks for the input and I will get back you after I figure out what went wrong
Old Jan 2, 2007 | 08:27 AM
mikeycivic's Avatar
thanks EE
Old Jan 2, 2007 | 09:34 AM
EJgsr's Avatar
the treads look good on the bolt because the block has "weaker" metal....
