-4an 10 micron pre-turbo oil filter
Old Jan 1, 2007 | 10:19 PM
Sprockets's Avatar
Default -4an 10 micron pre-turbo oil filter
As I'm preparing to make the switch from -3an to -4an so I can run the .035" restrictor, I came across small inline 10 micron cleanable filters with -4an male ends. Although my oil feed is filtered oil, when in bypass mode you're not getting filtered oil. I had considered getting a wire screen, but I think there would be more chances of this clogging. Anyway, does anyone else run a small inline oil filter before their turbo, and if so, where did you get it?
Old Jan 2, 2007 | 11:07 AM
Sprockets's Avatar
Default Re: -4an 10 micron pre-turbo oil filter (Sprockets)
No one here uses these?
Old Jan 2, 2007 | 07:20 PM
Sprockets's Avatar
Maybe if I made a post about blowoff valve sounds I'd get some opinions?
It sounds like a good idea to me, but I don't want to be a guinea pig.
Old Jan 2, 2007 | 07:45 PM
efeezie's Avatar
I ran a Earls 10 micron filter on my car for the longest never had a problem. Cheap insurance if you ask me
Old Jan 2, 2007 | 07:46 PM
creechrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">Maybe if I made a post about blowoff valve sounds I'd get some opinions?
It sounds like a good idea to me, but I don't want to be a guinea pig.</TD></TR></TABLE>
Very True.
I've thought about doing it but, that's about as far as I have gotten.
Good luck!
Old Jan 2, 2007 | 08:19 PM
Sprockets's Avatar
Default Re: -4an 10 micron pre-turbo oil filter (efeezie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efeezie &raquo;</TD></TR><TR><TD CLASS="quote">I ran a Earls 10 micron filter on my car for the longest never had a problem. Cheap insurance if you ask me </TD></TR></TABLE>
I was looking at the Earl's filters. They're cheaper than the other ones I looked at:
How do you like the Earl's? Is it easy to clean? One more question...How do you know it's 10 micron?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creechrr &raquo;</TD></TR><TR><TD CLASS="quote">I've thought about doing it but, that's about as far as I have gotten.
Good luck!</TD></TR></TABLE>
Thanks! As long as it doesn't alter fuel pressure, it should be OK.
lando griffin
Honda Civic (2006 - 2015)
Oct 15, 2007 12:07 PM
andreasofpartridgetrail
Feb 17, 2007 10:20 AM
coot_er
Aug 23, 2006 07:23 PM
alpha
Apr 18, 2006 10:13 AM
CW-ITR
Jun 18, 2004 03:57 PM
