is this true?
You can have a knock sensor not attached but grounded to the chassis and connected to your ECU. is it true? and what does he mean grounded to the chassis the knock sensor wire? heres the link its on the 25th paragraph. http://www.hondatuningmagazine...ngine/
Hooking up a bad sensor like that will still cause problems because the sensor is still bad.
If you wired a good sensor up like that your ECU would be happy to "see" a sensor but it wouldn't retard timing because your engine was knocking.
That sensor is pocket sized. Pick one up at a junk yard or buy one for $40-50 in the classifieds.
krysted9354
Sep 1, 2009 07:57 AM
