just bought an alpine deck 179.99 and got some cheap front spea...
kers... i was wondering about the rear panels because there are none, BTW i drive a (sig). what kind of rear plastic panels would u need to get to integrate rear speakers?
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I would not put rear speakers in your car if it does not have them. You could use that money to build a nice front stage set up. Plus the car is small enough to get away with easier
really? i didnt know that. okay well right now im installing some DUAL brand speakers (that came free) i know these are garbage but i plan to upgrade to like pioneer etc. what is a popular speaker that will fit into the door panel of my hatch?--- size and brand wise
i installed my deck and two speakers in the front (not sure what size but they are DUAL brand speakers) and when i roll down my window it hits the magnet.
please tell me what the correct size speakers the put in.....i plan to upgrade in a few days and want to know what size and brand to get.
Your 92 Civic uses standard 6.5" speakers in the doors, they will fit the stock plastic speaker housing, and if they are 2" or less, [mounting depth] they will fit without mods, up to a 2-3/4" deep speaker can be installed by cutting the back out of the stock plastic housings, [to allow for aftermarket speakers magnet].
It sounds to me like you have removed the stock speaker housings and mounted the speaker directly to the door skin.
94
94
there was tiny speakers to begin with with a wood spacer behind them...my new ones wont accept the spacer...and if i did use the spacer my speaker might hit the door panel......what is a popular setup in aftermarket speakers that fit well in my eg?--props on all the replies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Your 92 Civic uses standard 6.5" speakers in the doors, they will fit the stock plastic speaker housing, and if they are 2" or less, [mounting depth] they will fit without mods, up to a 2-3/4" deep speaker can be installed by cutting the back out of the stock plastic housings, [to allow for aftermarket speakers magnet].
94</TD></TR></TABLE>
just like fcm said, the deep is 2-3/4", speaker 6.5"
94</TD></TR></TABLE>just like fcm said, the deep is 2-3/4", speaker 6.5"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">there was tiny speakers to begin with with a wood spacer behind them...my new ones wont accept the spacer...and if i did use the spacer my speaker might hit the door panel......what is a popular setup in aftermarket speakers that fit well in my eg?--props on all the replies</TD></TR></TABLE>OIC, someone has already removed the stock speaker housings.
There are two things you can do, the easy thing is to hit up your local bone yard and find a set of stock plastic speaker housings and use a standard 6.5" speaker, you may even find a member here who has a set, [do you have a link to the HU and speakers you got?] the other thing you can do is make your own custom speaker housings.
94
94
