Oil Gauge question
As you all know I own a 91 2dr LS; I was rippin on the back roads pulling some g's around the corners, what I noticed was that my check oil light would turn on when I was on the more agressive turns. (checked oil levels warm and cold, all good) Is this normal for the oil to shift to one side of the engine? And is there anything I can do to reduce it; or should I not worry about it?
I had no idea you had a 91 2d LS, but you can buy a baffled oil pan that is designed to prevent oil starvation, Moroso comes to mind, but I am sure there are others. Be careful on public roads, never know when a Mack truck could be coming around the bend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dealer Leaf »</TD></TR><TR><TD CLASS="quote">I was rippin on the back roads pulling some g's around the corners, </TD></TR></TABLE>
Um .. Okay? Pullin some good ole G's huh?
Either you have a bad oiling system, or it really Was low,
With how many "G's" an integra can pull, it shouldn't bring the light up.
Buy a larger size pan if it really bothers you I guess ..
