Best Bang for Buck
Old May 13, 2002 | 06:44 PM
G unitvdvdv's Avatar
Default Best Bang for Buck
One word: JACKSON, reason: throw it in and forget about it
Sick power, linear set up= so reliable, and at least 1 sec of 1/4 mile time.
Dont get me wrong i was gonna do turbo but the pros just out weight the cons with the JACKSON
Old May 13, 2002 | 09:48 PM
CivicEx95's Avatar
Default Re: Best Bang for Buck (Jackson4Door)
who installed it for you and how hard was it? How much did it cost you?
Old May 13, 2002 | 11:10 PM
GSxRated's Avatar
Nah, for nearly the same price you can get a lot more hp/tq out of a turbo. And if you have half a head on you and keep the maintenance up the turbo will be a lot more satisfying, unless of course you just want a little more boost for daily driving (SC)
Old May 13, 2002 | 11:16 PM
Slain's Avatar
did u upgrade ur fuel pump ??? any dyno sheets ??
Old May 14, 2002 | 07:14 AM
Mista Bone's Avatar
D Tranny Guru
hey biter, never bit into a bottle????
1.7 seconds faster for $500.
Old May 14, 2002 | 07:30 AM
BoM's Avatar
BoM
Default Re: Best Bang for Buck (GSxRated)
do u forget all the money turbo drains...u going to need more than just a kit, boost controller, new injectors, standalone, 3inch exhaust ect...
Old May 14, 2002 | 08:01 AM
JMX's Avatar
JMX
Default Re: Best Bang for Buck (BoM)
but u got what 40 hp from the SC, and with a turbo, i,ve seen people pull 200whp on an LS wiht stock internals which is about double the whp of the car
so turbo is a better investment easily
Old May 14, 2002 | 08:16 AM
b18b98's Avatar
Default Re: Best Bang for Buck (jmx2323)
i still think nitrous and good tuning is the best bang for your buck
Old May 14, 2002 | 09:02 AM
brcivic411's Avatar
Default Re: Best Bang for Buck (b18b98)
i agree.. but then again, if you love to squeeze, you'll be paying for refills
i think it depends on what he's shooting for. if he's not wanting a drag racing monster, the SC is a nice package.. but if you want to up the boost that's a different story.
how much boost are you running?
Old May 14, 2002 | 12:01 PM
I agree but w/ the jackson you just throw it in and forget, as far as daily driving it is much better then turbo. Turbo without time and management is nothing but time and headaches. People always say 40hp, that is such bs its not even funny, the gs-r puts lets say 150 to the wheels on a good day stock, on a bone stock gs-r with 6 psi jackson it puts over 210 out, with much more low end that hondas lack. Mine with 8 psi and a little other work puts over 240 out and have had no problems.
Old May 14, 2002 | 12:02 PM
Default Re: Best Bang for Buck (Slain)
Yes, i upgraded to the 255lph walbro and i do have dyno sheets but no equipment to put them on the computer, sorry
Old May 14, 2002 | 12:04 PM
Default Re: Best Bang for Buck (Mista Bone)
lets see how many times you have to fill that squeeze happy bottle and how much it costs in the long run..
Old May 14, 2002 | 12:05 PM
yes, thank you, good call
Old May 14, 2002 | 12:55 PM
GSxRated's Avatar
Toss it in and forget about it huh? Your car is under constant boost, even at idle, Superchargers are not the end all to adding power without having to tweak and tune occasionally.
Old May 14, 2002 | 01:05 PM
WAFFLES's Avatar
and JRs little water coolers are notorious for quitting.
Old May 14, 2002 | 02:19 PM
Default Re: Best Bang for Buck (WAFFLES)
you dont need the water cooler with proper ignition timing, the water cooler is just like a fail safe, a waste of $$ if you ask me
Old May 14, 2002 | 02:20 PM
that is true, but they have tuned them so they run next to no boost, less then 1% now, like its in vacuum but as soon as you womp it the boost is right there...no hesistation due to the linear design
Old May 15, 2002 | 04:35 AM
Mista Bone's Avatar
D Tranny Guru
That is the key. Lower upfront cost for same/better performance. I have about $1000 so far in my ZEX NOS setup counting 20-25 fills. I could sell my ZEX kit tomorrow for $300 used. I bought it for $350 used.
Now if I was building a longterm motor, then I would go turbo.
D16Z6 + 85 shot = not long term!
Old May 15, 2002 | 10:02 AM
88_SC_CRX_Si's Avatar
New User
I thought the same about the water injection... Until I did some checking up. You can expect anywhere from 30-50 hp gain, just by cooling the intake charge... That may be a little high, the way some companys make numbers up... But still, any kind of gain like that, would be a nice bang for the buck. I will be finding out for myself, when the built motor gets built, I am having built....
Old May 15, 2002 | 02:17 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Best Bang for Buck (88_SC_CRX_Si)
THE Bang Bus Baby.
Old May 15, 2002 | 05:14 PM
well, i have the 6BTM MSD Igntion and the timing is retarded some, do you think the liquid injection would still be benificial, and where did you see the drastic hp increase numbers. I have heard nothing of the sort
Old May 15, 2002 | 08:33 PM
CRVtecRex's Avatar
I had mine on for two years, problem free. Other than the normal maintenance, I didn't have to do anything else. True, it's not the end all but, if you want a quick car capable of keeping up with mustangs and camaro's and the like, and don't want the added maintenance issues, then the SC is a good deal. The only maintenance I had to do was check the belt tension once in a while. It all depends on what you want out of the car I guess. Just my $0.02
BTW, the jackson unit has a bypass valve, you are not always under boost.
Old May 15, 2002 | 10:42 PM
voltronR34's Avatar
Best bang for the buck?
$55.00 for an SCCA membership.
Old May 15, 2002 | 11:34 PM
broke1's Avatar
Default Re: Best Bang for Buck (voltronR34)
some guy just dyno'd his jrsc gsr at my friends shop. i <U>think</U> that the end results were 230hp and 150tq. i'm not sure what boost he was running or what his mods were other than hondata.
Old May 16, 2002 | 05:52 AM
New User
It's on their web site... It's an AquaMist pump, that JR slapps their name on.... hehehehe
http://www.aquamist.co.uk/
I am trying to do everything possiable to reduce the intake temp. Also, like mentioned above, you would be able to advance your timming some, sooo even more low end torque would be there.
