check eng light b16a crx
Old Jan 1, 2007 | 05:39 PM
vw eater's Avatar
Default check eng light b16a crx
hello i had my check engine light come on today and i checked the lights and there was 2 codes, a 1-o2 sensor and a code 3 map sensor. but when i start my car there is no check eng light but it blinks 3 times meaning map sensor what do u think abot this?i will check the 02 sensor on a lab scope tomorow and see if its good. i know the map sends pulse withs to the o2 to adjust the fuel so would that be throwing the 02 code? i have a 91 crx si w/ b16a in it w/ pr3 ecu
Old Jan 1, 2007 | 06:52 PM
hybridmiklo's Avatar
Default Re: check eng light b16a crx (vw eater)
The ecu will save the reason for the check engine light. If its your map you can test it. Or if you prefer buy one. Don't know how much they go for but I gots one and Located in Temecula.
Now that's scanless.
Old Jan 1, 2007 | 07:18 PM
vw eater's Avatar
i have a couple crx's, if i replace it w/ a nother one and it works will the code 3 instantly go out?so that way i will know its the map sensor then i can go buy one? thanks
Old Jan 1, 2007 | 08:01 PM
pegboy's Avatar
you can clear the codes after replacing the sensor. remove the hazard fuse (10A I think) from the engine bay fuse box for 10 seconds.
Old Jan 2, 2007 | 06:00 AM
vw eater's Avatar
ok i will do that today and see what happens
Old Jan 2, 2007 | 07:44 AM
gsxr1k05's Avatar
Default Re: (vw eater)
i thought map was code 5? least thats what mine was when i did my swap.. i had vacume lines hooked up wrong.. oh wait.. i just remembered that 3 and 5 are map. well, you can replace it with another one, clear the ecu memory and see if you get that code.. i am getting code 4 and 21 right now. cps and vtec spool. i should have it fixed today..
Old Jan 2, 2007 | 04:47 PM
vw eater's Avatar
thanks,
''you can clear the codes after replacing the sensor. remove the hazard fuse (10A I think) from the engine bay fuse box for 10 seconds.
is that the coresst way to reset the ecu?
Old Jan 3, 2007 | 07:00 PM
vw eater's Avatar
Old Jan 3, 2007 | 09:09 PM
143MYVTECEF's Avatar
just disconnect your battery for a minute or two and reconnect it.. just another way to do it.
Old Jan 4, 2007 | 04:45 PM
vw eater's Avatar
ok so i checked the o2 sensor today and there both bad. what do i order a 02sensor for?are they all the same?1 wire 02?
1993eghatch
Jun 24, 2010 03:25 PM
stripes777
Nov 30, 2009 07:24 AM
MIZIKETSK
Jun 15, 2004 06:36 AM
BeanRacer
Nov 24, 2001 11:15 AM
