some serious quetions about doing a ls swap
Old May 13, 2002 | 06:33 PM
phatcivic99's Avatar
Default some serious quetions about doing a ls swap
ok i have a 99 civic hb. i can get an ls engine and wiring harness for 750. i plan to turn it into a b20 turbo....in the future. i can take out a loan for 2000. will this be enough to get me started and about how much can i buy with this money.
now i am planing to do this right and the first time so i dont waste money. would it be better to get an after market ecu or a stock ls. what would be a good tranny for it. i dont have to have to engine in the car right away. so i can build it as money comes along. will ls axles be ok with the turbo or should i just get better ones now.
thank you for all your help. i know it will come in handy.
Old May 13, 2002 | 09:14 PM
97hb's Avatar
Default Re: some serious quetions about doing a ls swap (phatcivic99)
I would probably get a 99 or newer LS engine to keep your car legal. If you plan to turn it into b20 turbo, I would just get the b20z block(has knock sensor), then get LS tranny, LS intake manifold, LS head(optional) and axles. I have an LS swap in my 97 hatchback and am planning to just juice it (55shot) untill it dies and then just do a b20 with my tranny, ecu, and intake manifold. I might even use the LS head if thats not blown. I don't know if its true but most people on this board say the b20 and LS heads are the same. I have a haynes manual (it sucks but got me through the swap) and all the specs of the two heads are identical except that the exhaust cam has a little different grind. Don't know which is better, but I assume the LS is better because its in a more sporty car to begin with.
Old May 14, 2002 | 08:24 AM
Default Re: some serious quetions about doing a ls swap (97hb)
ok thanks anyone else.
Old May 14, 2002 | 12:12 PM
decypha's Avatar
unless that LS engine you can get is newer 98-up id get it but IMO
I would go straight to the B20..why waste time and money if thats what you want...just buy the a B20 engine, GSR tranny, and a LS intake manifold and axles...oh yeah and something for the PCV system..
As for the ECU..an LS would be ok for starters..when youre ready for turbo..thats when you upgrade to Hondata..
Old May 14, 2002 | 12:15 PM
burntpistons's Avatar
Default Re: some serious quetions about doing a ls swap (decypha)
slap turbo on LS motor and you 'll be fine, nuff said!
Old May 14, 2002 | 12:38 PM
Grimm's Avatar
Default Re: some serious quetions about doing a ls swap (burntpistons)
why not just get the gsr motor, not as much torque as the b20 but more than the ls? then a nice turbo?
Old May 14, 2002 | 01:43 PM
Default Re: some serious quetions about doing a ls swap (Grimm)
correct me if i am wrong but isnt an ls block stronger then a b20.
how much is a hondata ecu and where can i get one. will it work with out the turbo. i dont want gsr because everyone does them and i want to be different and i like the torque of the ls, b20.
how much do b20s usually run
thanks guys for your help.
Old May 14, 2002 | 02:25 PM
decypha's Avatar
B20 block is stronger than the LS...
if youre looking for hondata in your area..IM sgT...(Sakai) he's in VA..
http://www.sgt-racing.com
also for engine swaps and turbo..IMO id go to:
Inline-pro 1st
CDE motorsports..Brian is cool over there..
Autothority..too pricey..but Frankie and Manny there are cool too..
Nu-Image...Norris is shady..might jack your shiet after they install it..
Old May 14, 2002 | 04:00 PM
spankaveli's Avatar
go b20, ls head, ls tranny, boooost!!
Old May 14, 2002 | 07:06 PM
Default Re: some serious quetions about doing a ls swap (spankaveli)
ok thanks guys.
about how much will it cost to get a b20 on the road and in my car. minus the labor of putting it in the car.
thanks for your help
supaslowdx
Mar 25, 2010 12:26 AM
widecoupe
Apr 17, 2003 03:14 PM
Sassafrass
Jan 8, 2003 12:41 PM
maxxdout
Oct 17, 2002 06:55 AM
