bad head gasket?
Old Jan 1, 2007 | 03:03 PM
teddy_dc2's Avatar
Default bad head gasket?
i replaced my head gasket with another oem one when i upgraded my head studs last summer. now i find a lot of oil around my spark plugs and a slight oil drips around the bottom of the head. still runs fine and smooth but it's eating oil. could it be the rings? how would you know?
Old Jan 1, 2007 | 03:53 PM
DB1_559's Avatar
Default Re: bad head gasket? (teddy_dc2)
i think its your spark plugs seal that are on the valve cover im about 99% sure
Old Jan 2, 2007 | 01:34 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
yup it got to be the spark plug seal
Old Jan 2, 2007 | 02:55 AM
COME UP`S's Avatar
yeah there is a seal on the dizzy on the side its a small ring where it goes into the cams they go out to
Old Jan 2, 2007 | 08:59 AM
teddy_dc2's Avatar
how do you know if the h.g. is bad?
Old Jan 2, 2007 | 09:41 AM
JandMmotorsports's Avatar
Default Re: (teddy_dc2)
water in the oil/oil in the water compression/leak down test
Old Jan 2, 2007 | 08:25 PM
teddy_dc2's Avatar
well i'll give it a try, the oil seems in the cylinder not on top of the plug. comp test read left to right 1- 200psi, 2- 190psi, 3- 185psi, 4- 200psi,
Old Jan 2, 2007 | 08:34 PM
youdontknowmeeither's Avatar
i thought gsr's were supposed to have a lot more compression than that.
Old Jan 4, 2007 | 07:11 PM
teddy_dc2's Avatar
my buddy says his was about 210-220 across. mines is about 150k but i do take good care of her.
projcinco
Aug 28, 2008 06:10 PM
Singlecam4dr
Jul 7, 2006 08:49 PM
ghost_ryder35
Oct 23, 2004 08:16 AM
USDMMARK
11
Oct 1, 2003 07:22 PM
3rdGteg
Aug 9, 2002 12:04 PM
