Rear Dics Conv Question
Old Jan 1, 2007 | 02:25 PM
Djole_V's Avatar
Default Rear Dics Conv Question
Oke Im buying the parts to do the rear disc conversion on my 96 ex and im getting the master cylinder does it matter if I just buy this
or if i get the whole thing and why
Old Jan 1, 2007 | 02:34 PM
pdiggitydogg's Avatar
Different MC's have different bolt alignment than others. By buying a booster and MC set, youre eliminating the chance of misalignment.
IE - some are set at a 45* angle from the horizontal
(though neither of the two above are this way)
Plus, depending on the size of the mc you get, a larger booster may be a wiser choice (to help move that amount of fluid).
One last thing...you should get one larger than 7/8
Old Jan 1, 2007 | 02:37 PM
Djole_V's Avatar
Default Re: (pdiggitydogg)
Thanks yeah and there are both from an si or for an si civic but im just saying to I need to get the booster with it or it does not matter?
Old Jan 1, 2007 | 02:39 PM
If it lines up properly...it doesnt matter all that much, no.
You would be fine just getting the mc
Old Jan 1, 2007 | 02:42 PM
Djole_V's Avatar
Im getting the prop valve too so yeah i still have no idea but im probably going to go with the second one just too be safe.
Old Jan 1, 2007 | 02:46 PM
No point, if its from an em1...since all 96-00 have the same booster (9")
If youre getting an integra set, get the booster...
I just noticed...you have an EX - you already have that same MC.
Old Jan 1, 2007 | 02:47 PM
Djole_V's Avatar
Default Re: (Djole_V)
Yeah and im getting the Si brake stainless steel breake line are they same in the front on the ex too i think they are.
Old Jan 1, 2007 | 02:48 PM
lines up front are the same - rears are different
I edited my last post, if you didnt see... You already have a 7/8 MC (ex = si)
Old Jan 1, 2007 | 02:49 PM
Djole_V's Avatar
so the booster is the same on the 96-00 all models so it doesnt matter? Will the mileage on the car effect the booster cause i have a car that has aliitle more kliks?
Old Jan 1, 2007 | 02:51 PM
Correct on the booster...and its probably fine (Ive never heard a booster going bad).
But, like Ive said...you dont need ANYTHING, if youre getting it from an Si......since you already have that same setup.
Old Jan 1, 2007 | 02:52 PM
Djole_V's Avatar
All right thanks
skill178
16
Oct 9, 2011 04:38 PM
949
31
Oct 7, 2009 11:17 PM
Cold Fyre
Jun 25, 2006 09:45 PM
goldenk10
Jul 19, 2004 12:54 PM
Yokohama
Jan 27, 2004 09:40 PM
