honda-tech Guru ( electrical )
Old Jan 1, 2007 | 01:48 PM
bunburyd16y's Avatar
Default honda-tech Guru ( electrical )
my car got stolen couple of weeks ago and got it back(THANK YOU GOD THAANK YOU ARIZONA PD)
well there is a electrical short ,when i turn my lights on my fuse #8 blows up all the time, and only my night talilights,licensplate,side corners, instrument dash,lights go off.
i checked for cut cables found 2 ,but the problems persist.
before i tak it to a electrichian and get ripped off, i wanna consolt with you(honda-tech)
thanks
i hope this image can help
is fuse box under dash, by #37
Old Jan 1, 2007 | 01:54 PM
ED3_FTW's Avatar
Default Re: honda-tech Guru (bunburyd16y)
if the fuse is blowing, it means that too much amperage is being drawn through the circuit. which i would assume is a short to ground, or there is no load on the circuit
check for any crossed, or shorted wires first off.
oh and fuse 8 is for the headlights? or is that fuse for something else all together??
if it is protection for another circuit then, you definately have a cross short
Old Jan 1, 2007 | 01:58 PM
Default Re: honda-tech Guru (ED3_FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED3_FTW &raquo;</TD></TR><TR><TD CLASS="quote">if the fuse is blowing, it means that too much amperage is being drawn through the circuit. which i would assume is a short to ground, or there is no load on the circuit
if it is protection for another circuit then, you definately have a cross short</TD></TR></TABLE>
#8 controls all the things i mentioned above,
tailights,licensplatelights,side markers,instrument dash light,center conosole light,
i will check for a ground right now
Old Jan 1, 2007 | 02:14 PM
lightcrx's Avatar
did they steal your radio? if so the radio taps into that fues.... maby the wires are grounding to the frame
Old Jan 1, 2007 | 02:25 PM
Crx Jimmy's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">did they steal your radio? if so the radio taps into that fues.... maby the wires are grounding to the frame</TD></TR></TABLE>
X2 if they cut your radio wires it most likely is the wire that light up the radio when the lights are on, it is grounding out or shorted check that first
Old Jan 1, 2007 | 02:48 PM
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
X2 if they cut your radio wires it most likely is the wire that light up the radio when the lights are on, it is grounding out or shorted check that first</TD></TR></TABLE>
i woul of never thought of checking there
i just spent 15 minutes with my car turn on and lights on
after checking stereo ground cable
and tape over it
it seems the problems is gone
THANK YA'LL
AND
THANK THE
WWW.
FOR HONDA-TECH.COM
THANKS GUYS
Old Jan 1, 2007 | 03:32 PM
143MYVTECEF's Avatar
Default Re: (bunburyd16y)
Im glad you got your car back
Old Jan 1, 2007 | 05:08 PM
PACT man's Avatar
Default Re: (143MYVTECEF)
I blew the same fuse by having the red wire from the radio(that was poorly put in before me) touch ground.
monsterCHILD
Jan 6, 2011 04:28 PM
prelude-all-the-way
Mar 20, 2008 07:38 AM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
Pablo Escobar
15
Jul 4, 2006 07:24 PM
eyegiant
Honda Civic (2001 - 2005)
11
Jun 7, 2006 03:09 PM
