f/s f/t 1998 teg /h22a inside
Here is my 1998 Acura Integra LS. The car has 108,000 Chassis Miles, and about 65,000 Miles on the Motor.. It has a JDM H22 5 Spd. Swap. The Integra is a Milano Red 2Dr. Here is some info...
1995 JDM H22A Engine Swap W/About 65K Miles, Professionally installed
JDM P13 ECU
Hasport Motor Mounts
LSD Transmission Only ~15k Miles!
Custom Transmission Gearing (Shorter 1st Gear)
ACT Street/Strip Clutch
ACT Lightweight Flywheel
Head has a Mild Port and Polish
AEM Short Ram Intake Power Coated Black
Complete H22 Shifter Assembly
JDM Header
2 ¼ cat back
Test Pipe
Vtec Hits at around 5500 RPM
16inch ikon wheels with brand new Bfgood tires
Black/Grey GSR Front Seats /rear also
Black OEM Floor Mats
JDM ITR Carbon Fiber Overlay on Entire Center Console
Gauge Cluster and Instrument Cluster all Light up Red/Amber
Pioneer head unit
Aftermarket Rear Speakers
Type R Shift ****
Battery Relocated to Trunk (In Box)
Cross Drilled and Slotted Rotors (Front and Rear)
EBC Green Stuff Pads
Full Tein Basic Suspension (Adjustable)
Full Camber Kit
Skunk 2 Rear Lower Tie Bar
Maintence...
Brand New Distributor from DistributorKing.com (~$300 shipped, have receipt)
Brand New Bosch Platinum 4 Plugs ($7 each) and Wires
Fresh Oil Change (Synthetic Only)
Always used 93 Octane
Brand New Timing Belt/Balancer Belt Installed 5k Miles ago (Have Receipt)
Brand New Passenger Side Fender Liner
Brand New Horn (Needs Installed)
Brand New Battery W/Warranty
ECU Mounted on floor with Plexi Glass View Window
Just Look At That Engine!!!
No Power Steering (Handles Awesome Though)
No Air Conditioning
No Cruise Control
No Rear Seat Belts
Problems: 5th gear as a slight grind above 3 grand but if you double clutch it. It will not grind at all
Check light comes on sometimes for the egr valve with causes it to idle alittle funny sometimes usally for 15-30 seconds then it evens its slef out
Body has no rust on it very very veyr clean but could use a good buff has a small crack in front bumber
Price is 6,500 obo or 96-00 civic hatch or coupe will take trades plus cash
DOES NOT COME WITH CARBON FIBER HOOD
Modified by streetspeed607 at 4:21 AM 1/1/2007
Modified by streetspeed607 at 12:07 AM 1/16/2007
JDM P13 ECU
JDM Header
2 ¼ cat back
Test Pipe
Pioneer head unit
Type R Shift ****
Full Camber Kit
Maintence...
No Air Conditioning
No Cruise Control
No Rear Seat Belts
4NLINE UNLIMITED
Apr 8, 2007 11:59 PM
