4 wire o2 pin out for cx????
Old Dec 31, 2006 | 05:02 PM
BOMBCRU's Avatar
Default 4 wire o2 pin out for cx????
trying to find out what color wires on a 4 wire o2 pin out at on a obd1 ecu for a 95 civic using p28
this is all i can find on pin outs
i need the last 2 pin outs with wire color to pin position
a6 6-PO2SHTC O2 sensor (heating element) Org/Wht, Battery Voltage with KOEO
14-PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
Old Dec 31, 2006 | 05:50 PM
BOMBCRU's Avatar
Default Re: 4 wire o2 pin out for cx???? (BOMBCRU)
never mind found it after a hour of looking
Using a P28 ECU (and should work for most obd1 ecu's with 4-wire controls)
Run O2 Sensor signal (white) To D14
Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control (black) to A6
Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
Old Dec 31, 2006 | 09:17 PM
eg2solsi500's Avatar
Can I go from a 1 wire to a 4 wire ? I have a 93 hatch cx and mt 02 is bad. But i have a sapre4 wire that is almost new.
Old Jan 3, 2007 | 08:52 PM
BOMBCRU's Avatar
Default Re: (eg2solsi500)
lol i did, wasnt to hard, more time consuming trying to do wiring in the rain lol
Old Jan 3, 2007 | 10:04 PM
dustinO's Avatar
Yes, you can go to a 4 wire. Your just gunna have to run them to the proper pins on your ECU. Find a pin-out and go to town
WhiteVX
Sep 29, 2004 02:12 PM
Dancing is Forbidden
Nov 18, 2003 08:51 PM
7rrivera7
May 22, 2003 01:37 PM
