NEED HELP WITH BRAKES
Old Dec 31, 2006 | 02:35 PM
ozrednsx's Avatar
Default NEED HELP WITH BRAKES
*****EDIT*****
need help... alright i did an 11inch brake swap on all four corners...new rotors/pads and SS lines.
New 15/16 Civc ex MC with stock BB
4040 prop valve
PROBLEM: pedal isnt mushy but whether the car is on or off it takes like 2-3 pumps before it gets firm?
Modified by ozrednsx at 6:30 PM 12/31/2006
Modified by ozrednsx at 6:01 PM 1/5/2007
Old Dec 31, 2006 | 05:54 PM
welfarepc's Avatar
Default Re: NEED HELP WITH BRAKES (ozrednsx)
are you bleeding from the farthest breaks from the MC to the closest?
Dan
Old Jan 1, 2007 | 01:30 PM
ozrednsx's Avatar
Default Re: NEED HELP WITH BRAKES (welfarepc)
yup!
RR LF RL FR is how i do it.
i believe its the brake booster leaking
Old Jan 1, 2007 | 01:48 PM
ef-hatchcrap's Avatar
The brake booster is bad
Old Jan 2, 2007 | 04:05 PM
ozrednsx's Avatar
Default Re: NEED HELP WITH BRAKES (ef-hatchcrap)
bump
Old Jan 5, 2007 | 05:01 PM
ozrednsx's Avatar
bump i need help
Old Jan 5, 2007 | 06:00 PM
ozrednsx's Avatar
maybe bad calipers?
Old Jan 5, 2007 | 06:10 PM
A.'s Avatar
A.
Sounds like the Brake booster or Air in the lines. It doesnt sound a caliper problem. Master cylinder?
Old Jan 5, 2007 | 07:40 PM
KEVLARsh's Avatar
Default Re: (A.)
either brake booster or master cylinder i would say
Old Jan 5, 2007 | 10:02 PM
ozrednsx's Avatar
Default Re: (DK-Kip)
brand new MC...BB is good
found out it was that one of the pistons were stuck on the driver side caliper...
took all of them apart to rebuild
91integra91
13
Aug 20, 2011 09:00 AM
pythoner
Suspension & Brakes
Sep 3, 2008 04:01 PM
USDM-EK4*
Apr 4, 2008 07:50 PM
Jooleeus
Feb 24, 2008 09:20 AM
veejay
Jul 24, 2001 09:39 AM
