Timing belt install gone wrong
Old Dec 31, 2006 | 01:18 PM
skata89's Avatar
Default Timing belt install gone wrong
Well I replaced the timing belt along with new cam gears and when I went to start the car its just dies right away. So I thought I was off be a tooth or so end up everything lines up good. What else could cause my car to die when I start it? Could it be that the belt is too tight?
Old Dec 31, 2006 | 02:03 PM
BLacK FirE's Avatar
Default Re: Timing belt install gone wrong (skata89)
Did you check to make sure its lined up at the crank also?
Old Dec 31, 2006 | 02:06 PM
RTW DC2R's Avatar
if you arent sure you installed everything correctly, you should not be starting the car!
i hope you atleast tried to rotate the crank by hand a few times before starting it, which is what you are supposed to do.
Old Dec 31, 2006 | 02:08 PM
Dave-ROR's Avatar
If everything lines up and you are sure that the belt is installed correctly, start checking other things. Did you pull the plug wires off the dist? if so did you reinstall them in the correct order?
Just recheck everything you did, you'll likely find the problem.
Old Dec 31, 2006 | 02:17 PM
skata89's Avatar
Yes I rotated the crank before starting the car. All the lines line up good too so I know its now that. Maybe I did but the sparkt plug wires on wrong. Ill check that really quick. Any other ideas? like the belt being too tight?
Old Dec 31, 2006 | 02:24 PM
RTW DC2R's Avatar
Default Re: (skata89)
it can be too tight but I cant see that keeping the car from starting. did you use the correct tensioning method?
definitely sounds like something else is mixed up somewhere, plugs/wires is a good place to start
if looking at the distro from the passenger side of the car, Im pretty sure the plug wires go like this
3 4
1 2
Old Dec 31, 2006 | 02:28 PM
skata89's Avatar
And thats with the 1 facing towards the car? or is 1 facing towards the front?
Old Dec 31, 2006 | 02:30 PM
RTW DC2R's Avatar
que?
Old Dec 31, 2006 | 02:31 PM
crxgator's Avatar
1 will be facing towards the firewall (car)...but it would be like this
Old Dec 31, 2006 | 02:56 PM
skata89's Avatar
Ya I guess I put them on wrong or something. Thanks guys. Also now that its running its making a whinning sound from the belt. Will it be ok like this or should I loosen it up a little?
Old Dec 31, 2006 | 04:14 PM
RTW DC2R's Avatar
did u use the proper tensioning method? also make sure the belt isnt rubbing the black timing belt covers.
Old Dec 31, 2006 | 04:55 PM
Haleiwa-Brando's Avatar
Default Re: (RTW DC2R)
It's whining because it's too tight. It almost sounds like a blower
This could wear the belt out quicker and/or snap it.
Old Dec 31, 2006 | 09:27 PM
skata89's Avatar
Well right now theres about a 1/4 inch deflection in the front and very little in the back. So you think it should be a little looser?
Old Dec 31, 2006 | 10:20 PM
andyt's Avatar
Isn't it an automatic tensioner, I mean, how do you get it to be too tight or loose anyway? I just did this a few times trying to get my cam gears set correctly and I never had a problem with it being tensioned wrong.
Old Jan 1, 2007 | 04:45 AM
crxgator's Avatar
Default Re: (andyt)
by pushing the tensioner all the way tight with your hand and then tightening the bolt...
Old Jan 1, 2007 | 05:46 AM
skata89's Avatar
I used the coat hanger trick. Yall think that might have made it too tight?
Old Jan 1, 2007 | 06:39 AM
Runnerdown's Avatar
Yeah, dont yank to hard on the coathanger , just hold some tension. I like to run the belts a tad on the tight side but don't let it get tight enough to whine. Also, the belt gets significantly tighter when the engine is warmed up.
Old Jan 1, 2007 | 06:35 PM
RTW DC2R's Avatar
1/4inch is too tight IMO. why are you using the coat hanger method?
Old Jan 1, 2007 | 10:38 PM
mstewar's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, dont yank to hard on the coathanger , just hold some tension. I like to run the belts a tad on the tight side but don't let it get tight enough to whine. Also, the belt gets significantly tighter when the engine is warmed up.</TD></TR></TABLE>
same here.. I'd just loosen it up a bit.
EdwinCheng
May 7, 2014 01:28 PM
coreyhayman
Dec 30, 2006 05:45 PM
jus2sho
15
Oct 9, 2006 03:26 PM
