wheel weights
so im gonna paint my steelies pretty soon, but i have noticed that there are wheel weights. i dont want to paint over them because if they ever get removed there will be a spot that hasnt been painted. so 1 question is how do i remove them, and the second question i have is, when i go get new tires and what not can they put the weights on the inside of the wheel? thanks in advance
yes the weights can be put inside if you like.....to get them off we use a special weight puller at work...but if i remember right you can use a something with a pointed flat edge and a hammer and tap it in between the weight and wheel and it should come loose enough to take it off with a pair of pliers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">but if i remember right you can use a something with a pointed flat edge and a hammer and tap it in between the weight and wheel and it should come loose enough to take it off with a pair of pliers</TD></TR></TABLE>
But will he be able to get them back on?
they were easy to pop off with a screwdriver and a hammer. and i wont be putting them back on, i will have the tire place whoever they may be put them back on only on the inside, when i get new tires cuz mine are basically slicks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">to old man neri...yes he could have with a hammer tap it back on if he had chose to....but he wasn't planning on </TD></TR></TABLE>
Good to know.
Good to know.
ViZ
Jan 3, 2004 08:47 PM
